07-17-2014, 16:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | LG Flash Tool 2014 - The best way to Flash LG KDZ Rom 1. Version: + Build 25/06/2014 : Initial Version + Build 27/06/2014 : Fix not working with windows XP + Build 03/07/2014 : Fix not working with some machine run windows 8/8.1 64bit 2. What's news: + This is a modified version of UpTestEX v1.2.3.1 and working with all LG Smartphone Models + Re-design GUI simpler. + Working without LG Mobile Support Tool installed ! + Working with lastest version of LG Mobile Support Tool. + Dont need to use hosts file or run http server to bypass anymore ! + Default language is set to English. Don't need to choose language any more ! 3. Tutorial: + Download and setup LG Driver : http://www.mediafire.com/download/g3...Ver_3.11.3.exe + Download LG Flash Tool 2014 tool and extract : http://www.mediafire.com/download/fw..._Tool_2014.zip + Enter to Download Mode and plug USB into your PC + WARNING : Remember copy KDZ file into LG Flash Tool 2014 folder + Run LGFlashTool2014.exe and do as following pictures : + If you cannot run LGFlashTool2014.exe, please install Visual C++ Runtime Library : https://googledrive.com/host/0B9l4QO...tInstaller.exe[/SIZE] Normal Flash: Flash ROM without losing any data. Only use this when you need to fix system error. Beware of boot loop when flashing ROM that differ from current ROM on your phone or MOD ROM. CSE Flash: Choose this option when you need a fresh format. All data will be gone. It's suitable for upgrading or downgrading ROM or simply use this when you need to back to Stock. No need to choose desired language, it automatically change to English as a default setting. resources xda BR Qaisar Mahmood |
The Following 28 Users Say Thank You to Qaisar Mahmood For This Useful Post: |
07-18-2014, 11:51 | #3 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | |
The Following 2 Users Say Thank You to Qaisar Mahmood For This Useful Post: |
12-04-2014, 09:39 | #5 (permalink) |
Insane Poster Join Date: Oct 2014
Member: 2267800 Status: Offline Sonork: 100.1666959 Thanks Meter: 12 | i was use this tool, with CSE mode. but when firmware finish extracted, this tool stop responding. in the detail report APP CRASH happened. i try with NORMAL mode. but when the tool flash my device, in 5% my device disconnect unexpectedly. i've already instal the driver with LG port, modem, and usb device. but that also happened again and again |
The Following User Says Thank You to abahwiranta For This Useful Post: |
01-11-2015, 14:47 | #7 (permalink) |
Freak Poster Join Date: Jan 2015 Location: faisalabad
Member: 2323951 Status: Offline Sonork: 100.1668590 Thanks Meter: 86 | sir i try today this softwere and file but not workin its face,,,, |
The Following User Says Thank You to daniel@foji For This Useful Post: |
04-11-2015, 16:48 | #10 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2377433 Status: Offline Thanks Meter: 1 | Thanks a lot Qaisar Mehmood. I have been trying to update my LG G Pro F240L since few days. Every other effort was vague but your tool worked. Yahoooo. Thanks |
The Following User Says Thank You to alaxee For This Useful Post: |
04-28-2015, 08:32 | #11 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: Banjul, The Gambia
Member: 1974557 Status: Offline Sonork: 00011nd Thanks Meter: 39 | Quote:
The Following User Says Thank You to ndubuaku For This Useful Post: |
04-29-2015, 14:46 | #12 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | it will keep saying two usb cable connected. pls whats the solution Quik cell phone disconet asking conect again whats the issu |
The Following User Says Thank You to .....::::GsmAdeel:::::..... For This Useful Post: |
06-20-2015, 19:42 | #15 (permalink) |
Freak Poster Join Date: Aug 2014 Location: West Africa Ng Gh RCI
Member: 2243088 Status: Offline Thanks Meter: 38 | hi bro i fail on Lg P500 with this soft stop process on 14% any others solution for revive that soft? |
The Following User Says Thank You to michaelzehie For This Useful Post: |
