Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG
Old 07-17-2014, 16:18   #1 (permalink)
Qaisar Mahmood's Avatar
Member: 226457
Sonork: 100.1604561
Thanks Meter: 14,902
LG Flash Tool 2014 - The best way to Flash LG KDZ Rom
1. Version:
+ Build 25/06/2014 : Initial Version
+ Build 27/06/2014 : Fix not working with windows XP
+ Build 03/07/2014 : Fix not working with some machine run windows 8/8.1 64bit
2. What's news:
+ This is a modified version of UpTestEX v1.2.3.1 and working with all LG Smartphone Models
+ Re-design GUI simpler.
+ Working without LG Mobile Support Tool installed !
+ Working with lastest version of LG Mobile Support Tool.
+ Dont need to use hosts file or run http server to bypass anymore !
+ Default language is set to English. Don't need to choose language any more !
3. Tutorial:
+ Download and setup LG Driver : http://www.mediafire.com/download/g3...Ver_3.11.3.exe
+ Download LG Flash Tool 2014 tool and extract :
http://www.mediafire.com/download/fw..._Tool_2014.zip
+ Enter to Download Mode and plug USB into your PC
+ WARNING : Remember copy KDZ file into LG Flash Tool 2014 folder
+ Run LGFlashTool2014.exe and do as following pictures :
+ If you cannot run LGFlashTool2014.exe, please install Visual C++ Runtime Library : https://googledrive.com/host/0B9l4QO...tInstaller.exe[/SIZE]
Normal Flash: Flash ROM without losing any data. Only use this when you need to fix system error. Beware of boot loop when flashing ROM that differ from current ROM on your phone or MOD ROM.
CSE Flash: Choose this option when you need a fresh format. All data will be gone. It's suitable for upgrading or downgrading ROM or simply use this when you need to back to Stock.
No need to choose desired language, it automatically change to English as a default setting.
+ Wait until 100% to complete !
resources
xda
Qaisar Mahmood
The Following 28 Users Say Thank You to Qaisar Mahmood For This Useful Post:
Old 07-18-2014, 09:31   #2 (permalink)
Member: 1895099
Sonork: 100.1647265
Thanks Meter: 146
where i download lg kdz files?
Old 07-18-2014, 11:51   #3 (permalink)
Member: 226457
Sonork: 100.1604561
Lg Phone Firmware List
Qaisar mahmood
The Following 2 Users Say Thank You to Qaisar Mahmood For This Useful Post:
Old 07-20-2014, 18:48   #4 (permalink)
Member: 2128671
Thanks Meter: 38
quangnhat123 lgviet VIETNAM
The Following User Says Thank You to gsm.phutho For This Useful Post:
Old 12-04-2014, 08:39   #5 (permalink)
Member: 2267800
Sonork: 100.1666959
Thanks Meter: 12
i was use this tool, with CSE mode. but when firmware finish extracted, this tool stop responding. in the detail report APP CRASH happened.
i try with NORMAL mode. but when the tool flash my device, in 5% my device disconnect unexpectedly. i've already instal the driver with LG port, modem, and usb device. but that also happened again and again
The Following User Says Thank You to abahwiranta For This Useful Post:
Old 01-11-2015, 07:26   #6 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 179
not working plz tell me other way to flash
The Following User Says Thank You to anil.prajapati For This Useful Post:
Old 01-11-2015, 13:47   #7 (permalink)
daniel@foji's Avatar
Member: 2323951
Sonork: 100.1668590
Thanks Meter: 85
Wink
sir i try today this softwere and file but not workin its face,,,,
The Following User Says Thank You to [email protected] For This Useful Post:
Old 01-30-2015, 15:09   #8 (permalink)
haroon008's Avatar
Member: 2062801
Thanks Meter: 41
lg bl20v onstuck hang logo
how to flash with LG Flash Tool 2014 in emergency mode
please reply me
The Following User Says Thank You to haroon008 For This Useful Post:
Old 04-08-2015, 14:36   #9 (permalink)
Member: 2349975
Thanks Meter: 49
Qaisar mahmood
Where do get flash files for this models of lg phones? Link please.
The Following User Says Thank You to Feturi For This Useful Post:
Old 04-11-2015, 16:48   #10 (permalink)
Member: 2377433
Thanks a lot Qaisar Mehmood. I have been trying to update my LG G Pro F240L since few days. Every other effort was vague but your tool worked. Yahoooo. Thanks
The Following User Says Thank You to alaxee For This Useful Post:
Old 04-28-2015, 08:32   #11 (permalink)
Member: 1974557
Sonork: 00011nd
Thanks Meter: 29
1. Version:
2. What's news:
3. Tutorial:
resources
xda
Qaisar Mahmood
sir i try to use this tool with normal flash but would go up to 15percent and disconnect, i also try cse flash mode thesame, it will keep saying two usb cable connected. pls whats the solution
The Following User Says Thank You to ndubuaku For This Useful Post:
Old 04-29-2015, 14:46   #12 (permalink)
.....::::GsmAdeel:::::.....'s Avatar
Member: 767472
Sonork: 100.1609877
Thanks Meter: 596
Quik cell phone disconet asking conect again whats the issu
The Following User Says Thank You to .....::::GsmAdeel:::::..... For This Useful Post:
Old 05-22-2015, 14:05   #13 (permalink)
cooloxf's Avatar
Member: 120893
Thanks Meter: 68
is this work for lg d100 l20 if yes someone get the flash??
The Following User Says Thank You to cooloxf For This Useful Post:
Old 05-30-2015, 07:11   #14 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,490
Yes, this process should work on D100 too.
The Following User Says Thank You to nasirahmed For This Useful Post:
Old 06-20-2015, 19:42   #15 (permalink)
Member: 2243088
Thanks Meter: 31
hi bro i fail on Lg P500 with this soft stop process on 14%
any others solution for revive that soft?
The Following User Says Thank You to michaelzehie For This Useful Post:
Page generated in 0.44418 seconds with 7 queries
