Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > LG
Old 01-02-2011, 07:05   #16 (permalink)
Moderator
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Z3x encrypcts only QUALCOMM firmwares, others are same as original, so can be used.
The Following 5 Users Say Thank You to nasirahmed For This Useful Post:
Old 01-02-2011, 08:58   #17 (permalink)
rumenshom's Avatar
Member: 899774
Sonork: 100.1586303
u are always rocking for LG section
thanks for ur great contribution
Old 01-02-2011, 09:59   #18 (permalink)
visit999's Avatar
Member: 1013130
Sonork: 100.1605132
verry good...............Thank.
Old 01-02-2011, 14:04   #19 (permalink)
Member: 33958
~INFINEON~
Phones based on Infineon platform are flashed with GSMulti software. GSMulti has different versions like 20, 21, 30. The last one is GSMulti V30 and it supports all infineon phones till now. Infineon phones can be flashed both in USB and UART mode. Normally USB should be used, it will flash the phone in minutes where UART will take hour(s). Sometimes when phone is dead or rebooting and can't install USB driver you need to use UART then. Some old phones support only UART.
Infineon flashing on UART
1. You need a USB to Serial Converter BOX/Cable with correct pinout of the phone.
2. Install and run GSMulti v30
3. Go to Setting(s) > Configuration, select DLL and firmware on S/W box, select UART as communication, select correct port of Box/cable, then click OK.
4. Now click START on main window, when the software says Wait Phone Connecting... connect POWERED OFF phone with battery to cable and press POWER button.
Infineon flashing on USB
1. Install GSMULti V30
2. Connect phone to usb cable without battery, Windows will ask for driver, show driver from C:\GSMULTI\UsbDrivers\INFINEON.
3. Open USBMap from C:\GSMULTI, select INFINEON and click MAPPING START, reconnect the phone to usb cable without battery. Some info will show on PORT/KEYNAME, now SAVE & EXIT.
4. Open GSMulti main software, go to Setting(s) > Configuration, select DLL and firmware on S/W box, select USB as communication then click OK. Now click START on main window, when the software says Wait Phone Connecting.. reconnect the cable. If flashing not start without battery just put the battery and slightly press power button.
Hi,
Where can i find DLL & SW files ?
Thanks in advance for your help
Old 01-02-2011, 14:23   #20 (permalink)
rafiqcell's Avatar
Member: 979016
Sonork: 1592061
100% work tested me km900
The Following User Says Thank You to rafiqcell For This Useful Post:
Old 01-02-2011, 16:49   #21 (permalink)
Moderator
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
@habib76
Lot of firmwares and dll's are shared by our members, just look around this LG section, there is a search option for you. Moreover, if you need other what you can't find, ask here, I'll try to upload.
The Following User Says Thank You to nasirahmed For This Useful Post:
Old 01-02-2011, 16:56   #22 (permalink)
Member: 1420214
nasir bhai, u r the best
Old 01-02-2011, 17:35   #23 (permalink)
Member: 1420214
need vedio tutorial,if possible,please upload.
i'm new in gsm line
Old 01-03-2011, 05:21   #24 (permalink)
Oxegen's Avatar
Member: 1439406
i'm new in gsm line
what type video u want?
Old 01-03-2011, 12:52   #25 (permalink)
Member: 1420214
just video tutorial need,
any type/format
Old 01-03-2011, 16:21   #26 (permalink)
Member: 497475
need gd350 dll
Thank u
Old 01-04-2011, 05:40   #27 (permalink)
Oxegen's Avatar
Member: 1439406
any type/format
Following the the tutorial on how to flash the LG Phone with the GSMulti v3.0
1. Install GSMulti, Install The Infinion USB driver, also install the TI_Neptune driver too.
2. Copy the firmware folder to the GSMulti folder on c:, read also the pdf file from the GSMulti, read it start from 128..
3. Restart your computer
4. Take the battery out of your phone plug your usb cable into your phone but not the computer
5. Run USBMap_V01, select Infinion at the top of program window, press mapping start, plug the usb cable into your computer, when usbmap finds your phone press save & exit.
6. Unplug the usb cable from computer.
7. Run GSMulti, go into configuration and select the Dll file and FLS files that are in the folder and select USB in port information and select ok
8. Press Start and then connect the USB cable to the computer, flashing should now start. If flashing works, you should then use the LGUtils as normal to upgrade to a better firmware as this is an old firmware but its the only one to be found that works with GSMulti but at least it gets your phone working again.
Old 01-04-2011, 05:51   #28 (permalink)
Oxegen's Avatar
Member: 1439406
Originally Posted by meme1 View Post
need gd350 dll
Thank u
I haven't it and also don't know other what model's .dll can work or not
U have to wait for thread starter
Old 01-04-2011, 06:50   #29 (permalink)
Moderator
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
need gd350 dll
Thank u
GD350 DLL
GD350_100527.rar
The Following 4 Users Say Thank You to nasirahmed For This Useful Post:
Old 01-13-2011, 16:01   #30 (permalink)
Member: 430149
need firmware for GW825V do u have it???
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Upgrade 5110 to 6110? tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-28-1999 19:59
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.27782 seconds with 9 queries
