-   LG (http://forum.gsmhosting.com/vbb/f177/)
-   -   LG G3 (D855) Mcafee security (http://forum.gsmhosting.com/vbb/f177/lg-g3-d855-mcafee-security-1961876/)
nikosfireblade 06-23-2015 10:59
Hi to all..
I need a solution for LG G3 to unlock it from Mcafee security..
Hard reset the phone but after stuck on Mcafee security...
When i boot to download mode, to flash the phone ,says "kill switch" and restart the phone...
I search and i find a solution to root the phone and after i delete mcafee, but i cant go to settings and turn on USB debbuging..
Have anyone solution?
jawi 06-23-2015 11:06
Originally Posted by nikosfireblade (Post 11125055)
Hi to all..
which fw version u have? if u have 5.0 just downgrade;)
nikosfireblade 06-23-2015 11:18
I have 5.0...but i cant downgrade because when i put on download mode say "disable by killswitch" and restart..
Do you know how i can downgrade?
nikosfireblade 06-24-2015 17:02
I find the solution...:D
1. Turn off the phone ,hold volume down and connect to pc via usb..appeared the battery on lcd..(do this step, to no open mcafee very quickly)
2. Turn on the phone..
3. Go quickly to Settings-General-About phone-Software Information- and press 7 times "build Number" to open the developer options..
4.Go quickly to Settings-General-Security-Phone administrators and deactivate mcafee...(will be not done )
or go quickly to Settings-General-Developer options- turn on USB debugging..
These steps will be done more times ,i do 3,4 times on every step ,to no open Mcafee..
5 When mcafee not open , disconnect phone from pc and activate USB debugging..
6 Open Octopus or other program (i use octopus box) connect the phone to pc,and root the phone..
7 Download "titanium backup" from Market...
8 Open titanium backup and uninstall Mcafee...
Thats it...Your phone Works again without mcafee!!!
DomnulV 10-28-2015 09:53
Yes..mcafee start slow..but all is grey...inclusive USB debuging....
Developer mode is ok, but can not enter in usb debuging..all is gray..not work checkboix for enabled..
TNX,
Cris
majdykhrais 05-13-2016 22:15
Just enter 123456 for the PIN.
It worked for me.
rajashehryar 05-21-2016 15:06
i had a same issue before but i solved it successfully
basically i update my fone with TOT and DILL file through SP Flashing TOOL
This problem actually comes with TOT file or Built-in ROM .
if you get an error like "disable by killswitch" then turn off your mobile for 2-3 hours after 2-3 hours your mobiles access DOWNLOADING MODE .
if you have OCTOPUS box then download firmware from their SUPPORT
connect your phone with ( P999 ) cable and Flash the desire file
your G3 will be back to its original state
g5phone 09-08-2016 12:51
It worked for me.
It worked for me.
lovewar01 01-13-2017 02:59
It worked for me....
Thanks g5phone for the post. Guess the default pin wasn't changed after all.
gsmanam 09-07-2017 08:25
LG Firmware
Jul 29 2017 06:29:02 AM http://storagecow.eu/dlf/folder.pngCanada D852/ - Jul 29 2017 08:54:12 AM
http://storagecow.eu/dlf/folder.pngChina/ - Jul 29 2017 06:30:59 AM
http://storagecow.eu/dlf/folder.pngD850PR MM/ - Jul 29 2017 06:31:00 AM
http://storagecow.eu/dlf/folder.pngD855/ - Jul 29 2017 10:11:57 AM
http://storagecow.eu/dlf/folder.pngD855P/ - Jul 29 2017 06:53:31 AM
http://storagecow.eu/dlf/folder.pngKorea F400/ - Jul 29 2017 10:36:11 AM
http://storagecow.eu/dlf/folder.pngMarshmallow 6.0/ - Jul 29 2017 08:36:04 AM
http://storagecow.eu/dlf/folder.pngSprint LS990/ - Jul 29 2017 10:43:25 AM
http://storagecow.eu/dlf/folder.pngT-Mobile D851/ - Jul 29 2017 10:44:59 AM
http://storagecow.eu/dlf/folder.pngVerizon VS985/ - Jul 29 2017 10:48:06 AM
http://storagecow.eu/dlf/unknown.pngD850PR20A_01.kdz 1175562KB Mar 14 2017 07:38:35 PM
http://storagecow.eu/dlf/unknown.pngD85520A_00.kdz 1100994KB Jul 03 2015 06:27:44 AM
http://storagecow.eu/dlf/unknown.pngD85520h_00.kdz 1136228KB Jul 03 2015 06:28:09 AM
http://storagecow.eu/dlf/unknown.pngD85720c_00.kdz 1029392KB Oct 12 2015 12:42:45 AM
http://storagecow.eu/dlf/unknown.pngUS Cellular US99020a_24.kdz 1274106KB Jul 17 2015 01:23:35 AM
Talha34214012 10-04-2017 21:21
Solution
Hi to all..
Can easily be done via Oct**us LG or via BoardDiag Software by putting in Qualcom 9008 mode.
ahmer5050 03-26-2018 11:38
Yes Also Good Luck for me .Just enter 123456
jabbar arain 02-21-2019 13:04
123456 is not working for me
Page generated in 0.28788 seconds with 5 queries
