Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG
Old 06-23-2015, 10:59   #1 (permalink)
Member: 945371
Thanks Meter: 10
LG G3 (D855) Mcafee security
Hi to all..
I need a solution for LG G3 to unlock it from Mcafee security..
Hard reset the phone but after stuck on Mcafee security...
When i boot to download mode, to flash the phone ,says "kill switch" and restart the phone...
I search and i find a solution to root the phone and after i delete mcafee, but i cant go to settings and turn on USB debbuging..
Have anyone solution?
Old 06-23-2015, 11:06   #2 (permalink)
Member: 737720
Thanks Meter: 1,421
Originally Posted by nikosfireblade View Post
Hi to all..
which fw version u have? if u have 5.0 just downgrade
Old 06-23-2015, 11:18   #3 (permalink)
Member: 945371
Thanks Meter: 10
I have 5.0...but i cant downgrade because when i put on download mode say "disable by killswitch" and restart..
Do you know how i can downgrade?
Old 06-24-2015, 17:02   #4 (permalink)
Member: 945371
Thanks Meter: 10
I find the solution...
1. Turn off the phone ,hold volume down and connect to pc via usb..appeared the battery on lcd..(do this step, to no open mcafee very quickly)
2. Turn on the phone..
3. Go quickly to Settings-General-About phone-Software Information- and press 7 times "build Number" to open the developer options..
4.Go quickly to Settings-General-Security-Phone administrators and deactivate mcafee...(will be not done )
or go quickly to Settings-General-Developer options- turn on USB debugging..
These steps will be done more times ,i do 3,4 times on every step ,to no open Mcafee..
5 When mcafee not open , disconnect phone from pc and activate USB debugging..
6 Open Octopus or other program (i use octopus box) connect the phone to pc,and root the phone..
7 Download "titanium backup" from Market...
8 Open titanium backup and uninstall Mcafee...
Thats it...Your phone Works again without mcafee!!!
The Following User Says Thank You to nikosfireblade For This Useful Post:
Old 10-28-2015, 09:53   #5 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 97
Yes..mcafee start slow..but all is grey...inclusive USB debuging....
Developer mode is ok, but can not enter in usb debuging..all is gray..not work checkboix for enabled..
TNX,
Cris
Old 05-13-2016, 22:15   #6 (permalink)
Member: 427492
Just enter 123456 for the PIN.
It worked for me.
The Following User Says Thank You to majdykhrais For This Useful Post:
Old 05-21-2016, 15:06   #7 (permalink)
Member: 2568831
Sonork: 100.1675168
i had a same issue before but i solved it successfully
basically i update my fone with TOT and DILL file through SP Flashing TOOL
This problem actually comes with TOT file or Built-in ROM .
if you get an error like "disable by killswitch" then turn off your mobile for 2-3 hours after 2-3 hours your mobiles access DOWNLOADING MODE .
if you have OCTOPUS box then download firmware from their SUPPORT
connect your phone with ( P999 ) cable and Flash the desire file
your G3 will be back to its original state
The Following User Says Thank You to rajashehryar For This Useful Post:
Old 09-08-2016, 12:51   #8 (permalink)
Member: 1202938
It worked for me.
Old 09-08-2016, 12:51   #9 (permalink)
Member: 1202938
It worked for me.
Old 01-13-2017, 03:59   #10 (permalink)
Member: 883870
It worked for me....
Thanks g5phone for the post. Guess the default pin wasn't changed after all.
Old 10-04-2017, 21:21   #12 (permalink)
Member: 2594096
Thanks Meter: 17
Solution
Hi to all..
Can easily be done via Oct**us LG or via BoardDiag Software by putting in Qualcom 9008 mode.
Old 03-26-2018, 11:38   #13 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 827
Yes Also Good Luck for me .Just enter 123456
Old 02-21-2019, 14:04   #14 (permalink)
Member: 2854785
123456 is not working for me
Page generated in 0.25001 seconds with 8 queries
