Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG
Old 08-01-2015, 00:03   #1 (permalink)
Member: 2437649
Lightbulb LG-LS980 Could not Detect problem
Hello,
Read a lot here and got some progress but still can't unlock the phone.
It is a Sprint device.
I enabled debugging and have all drivers installed and the newest 2.0.3 LG Software. The ADB is recognized and operational but phone is still not detected.
I tried in Download mode and get some information but can't unlock the phone. It tells me this:
Checking data...OK
Platform: LG Qualcomm
Selected port: COM5
Selected model: LS980
Reading info...
Model ID: LG-LS980
IMEI: 990002-52-229069-9
Android version: 4.2.2
Battery level: 100%
Mode: Emergency
Initializing flash...OK
SW version: LS980ZVG_04
LAF Version: 1.1
Product ID: YE01S131109003453
Target operator: SPR
Hardware: rev_10
Unlocking...
Initializing ADB...OK
Waiting for phone...
Please, reconnect phone, enable USB debugging, and try again.
To enable USB debugging, please perform the following steps:
1. Disconnect cable
2. Install LG Android ADB drivers
3. Go to "Settings" -> "About phone" -> "Software information"
4. Click on Build number 5 times
5. Enable "Settings" -> "Developer options" -> "USB debugging" option
6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.
I have done all these steps and USB Debugging is enabled.
I also tried to connect as LG-LS660 and receive the following:
Selected port: COM4
Selected model: LS660
Reading info...
Waiting for phone...OK
Model ID: LG-LS980
Firmware version: LGLS980AT-00-ZVG-SPR-US-MAR-31-2015+04
Kernel version: 3.4.0-perf-g99690cb (lgmobile LGEARND16B11) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Tue Mar 31 09:15:37 KST 201
Android version: 5.0.2
Hardware: Qualcomm MSM8974 ARMv7 Processor rev 0 (v7l)
Please, type ##3424# to get SPC / MSL / Service Code...Failed!
I checked and the ##3424# is Diag enabled.
Please help, running out of options here and I am positive it should be something simple.
Should I try and upload a new Firmware file that I have downloaded ?
I am trying to make this phone work on T-Mobile 4G LTE Network.
Will appreciate any help!
Old 08-01-2015, 08:14   #2 (permalink)
Member: 2437649
Solved
After multiple hours of installing different drivers and virtual machines with 32bit OS etc. finally read in one of the forum posts to enable the phone in simple charging mode instead of MTP or PTP after connecting it in Debugging mode.
Can't believe how long that took me to solve
Now back on to the mission to unlock it for T-Mobile!
Will report how that goes.
Old 08-08-2015, 23:36   #3 (permalink)
Member: 2437649
SIM Unlock Succcessful
I found a thread with automated tool on XDA that I followed and it unlocked the Sprint LS980 to T-Mobile but the frequency that it runs is different than the original LTE and it runs at 2MBps on average which is very slow.
Not meant to be used on T-Mo LTE Network. I tested it after unlocking with the Octoplus box and it is easy unlock process to enable any non US SIM card to work. Hope that helps.
Old 08-09-2015, 03:18   #4 (permalink)
F_X
F_X's Avatar
Member: 2273678
Thanks Meter: 293
Hey bro, next time please inbox me if you need help...I will assist you with what I can
Old 08-09-2015, 03:57   #5 (permalink)
Member: 2136869
Thanks Meter: 10
yup f_x is an angel of gsm forum whom help newbies like me
thnx f_x for helping others
The Following User Says Thank You to Cute Khan For This Useful Post:
Old 08-09-2015, 17:13   #6 (permalink)
F_X
F_X's Avatar
Member: 2273678
Thanks Meter: 293
Thank you bro for your kind remarks, if I can help...why not right?
Page generated in 0.15535 seconds with 8 queries
