09-08-2013, 18:04 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2019180 Status: Offline Thanks Meter: 0 | LG-P698 Help Please I bought a LG-P698 I noticed that the strength of the network is weak from the first day and tried to return it did not happen ------------- With time beginning to show some of the things 1 - Lighting of the screen without touching it for short- periods and then started lighting periods exceeding even began to light up so heated and end up charging the battery and sometimes alone or when you restart it goes to a yellow screen in emergency mode 2 - despite the emergence of the network signal people call me find me out of service 3 - When you connect to the primary response from the speaker even though he is not enabled , which obliges me with every call I activate the loudspeaker and then cancel the activation to speak normally 4 - only rarely does not respond to connected to the computer , although the original use of the cable can not be open Les memory nor felt by PC Suite software I thought in the beginning that virus and revealed programs but did not find anything Sent for maintenance and they said to me that they had a firmware update And a few days after he returned back to him the problems in ascending I made a hard rest but no good news, it is the same by time its problems come back Firmware it is the last Arab V10g I noticed from the first day that there is a lack of this firmware when she saw the file on YouTube , where they found the English version , the first choice in the tools is update via Wi-Fi, this is my choice even after the update has been in agent Inquiry : Does this happen with all the owners of this device or this is special case ? Help : 1 - I made searchs to know how Flash device myself to find a solution to the problem but I didn't find DLL file so that I can't even now test flashing . so do anyone help me a to get this file ? I found a file but it is another model P698F 2 - Can flashing device in other language can help ? if this will make it stable I can use it in English language 3 -I found new firmware V10h but his language is SEA What is this language or area I apologize for the prolongation and thank in advance all of the support will be provided I'm sorry I wish my English is not too bad |
09-08-2013, 23:04 | #2 (permalink) |
Member: 2019180 Status: Offline Thanks Meter: 0 | I'm sorry, I had no time so that I used google translation, but when I read my post I fond it not clear because of bad translation, I can re-write a new post later if admins decide that it is not clear sorry again |
