01-07-2005, 19:47 | #3 (permalink) |
Freak Poster Join Date: Jan 2004 Location: N.E.Lincolnshire (UK) Age: 58
Member: 48437 Status: Offline Thanks Meter: 0 | I have tryd the LG U8110 drivers they went in ok but the unlocking software cant find the phone i looket in device manger for port which was 9 and still the program wont read so i tryd the normal software to try a ring tune still no luck what i am trying to do it unlock it i have got the furous unlocker for this phone any ideas will be greatfull i am on win xp if that helps |
01-07-2005, 19:50 | #4 (permalink) |
Freak Poster Join Date: Aug 2002
Member: 14297 Status: Offline Thanks Meter: 56 | hey u got the free software? i got the same problem the unlocking software dont find phone.. i made a thread,i need help to unlock my 8110 using the usb cable that came with phone to test if the 8110 drive are fully working try the phone manager if the finds ur phone via USB cable then the drives are working fine regards |
01-08-2005, 17:59 | #5 (permalink) | |
Member: 48437 Status: Offline Thanks Meter: 0 | Quote:
01-09-2005, 18:02 | #6 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | For all 3G handsets you can find drivers directly from THREE websites around the world, you just need searching. I think that you can find them at www.drei.at or www.tre.se. |
01-09-2005, 19:59 | #7 (permalink) | |
01-09-2005, 21:14 | #8 (permalink) | |
Member: 21296 Status: Offline Thanks Meter: 328 | Quote:
regards | |
01-09-2005, 22:22 | #9 (permalink) | |
01-09-2005, 23:23 | #11 (permalink) | |
here is the code that unlocket the 2 LG U8120 1/ Type the following 2945#*88110# 2/ Press ok 3/ press ok 4/ type 00000000 5/ turn off your phone 6/ switch back on your phone You should now be able to select your network. I got this infomation from a m8 and works for me but dont no if it will work on others but has done 2 of the above phones. hope some one can send me the drivers and on hunt for the software to alter something has got an other that is blocket to do to do the factory reset is 277634#*# and you can test many parts of your phone LG U8120 In Joy please try at your own risk all i can say it worket on 2 of them so far | |
01-10-2005, 23:36 | #13 (permalink) |
Junior Member Join Date: Jan 2005 Age: 47
Member: 103154 Status: Offline Thanks Meter: 0 | I have LG U8110 but when i do: 1/ Type the following 2945#*88110# 2/ Press ok 3/ press ok 4/ type 00000000 5/ turn off your phone 6/ switch back on your phone The phone does not unlock. If I reset it to factory default will it be unlocked, so all I do is put a sim in and it works??? Please help. |
01-11-2005, 10:14 | #14 (permalink) | |
this worket on ver 1.00 but i try on ver 1.05 and wont work but not tryd on other ver yet till get the other ver software | |
LG U8120 Driver [SOLVED] | gsmstars | FuriousGold | 1 | 09-03-2009 16:28 |
flash Lg U8120 to Lg U8130. | Mobile | LG | 1 | 07-19-2005 13:09 |
flash LG U8110 and LG U8120 | S.SHANTHIKUMAR | Cruiser Suite | 10 | 07-18-2005 10:32 |
LG U8120 USB drivers Needed | citifone | LG | 3 | 05-26-2005 08:56 |
LG u8120 usb drivers needed | kamransohail786 | LG | 3 | 04-08-2005 23:30 |
