06-21-2006, 15:44 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 253129 Status: Offline Thanks Meter: 0 | lg u880 big problem |
03-14-2007, 11:55 | #4 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: Milano, Italy Age: 37
Member: 62336 Status: Offline Thanks Meter: 115 | Quote:
If yes, just wait until the phone power off automatically and now start it in emergency mode, pressing 2 + 5 + Power On. Now flash the first file ( MUSEDR ) of your flash packet. After this, reflash the phone with all files. With Best Regards Bypx | |
03-16-2007, 18:07 | #5 (permalink) | |
Freak Poster Join Date: May 2005 Age: 62
Member: 149278 Status: Offline Thanks Meter: 7 | Quote:
thanks and best regards | |
02-08-2008, 09:08 | #11 (permalink) |
No Life Poster Join Date: May 2005 Location: Timisoara Age: 43
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | yes, same problem when press power = yellow screen when press "2" + "5" + power = only 3g logo when press "1" + "*" + "#" + power = yellow screen in any cases phone doesn't display "File System startup - Please Wait" and doesn't connect to computer so please what is the problem and how to fix it |
02-09-2008, 03:56 | #12 (permalink) |
Junior Member Join Date: Jun 2007
Member: 528671 Status: Offline Thanks Meter: 1 | Before you flash phone make sure USB Drivers are installed and Media has correct county code How to change Media Country Code 1. Download and install Hex Workshop 2. Run Hex Workshop, click file, open and select the media image 3. Ctrl+F a window will popup, under type select text string, under value type in FLEX_COUNTRY_CODE= 4. Change the value of "FLEX_COUNTRY_CODE=" to your country code 0:UK, 1:IT, 2:HK, 3:SW(sweden), 4U(Australia), 5:AU(Austria), 6E(denmark) 5. To change click infront of the number and put the desired value in. Make sure there is nothing overwritten V10 + V11 1. Hold buttons 2 + 5 and connect USB Cable 2. Phone will display 3 logo 3. Release buttons 4. Run LGMDP 5. Click Select Port 6. When phone is detected click connect 7. A window should pop up, select erase EFS 8. Then press start 9. After complete Remove battery and take out USB CABLE, after 10sec insert battery again and connect USB Cable (should display 3 logo), then detect phone on LGDMP 10. Insert Modem, Media and Module image and click start to begin flashing process 11. DONE!! If NAND WRITE FLASH Appears you have v11 firmware and this cannot be downgraded To revive v11 firmware download flash files from here and follow above steps V11a http:///vbb/showthread.php?t=463294 OR V11c http:///vbb/showthread.php?t=489860 THESE DO NOT UNLOCK PHONE JUST REVIVE IT!!! |
successfully unlocked LG U880 no problem on sim | eumore79 | Rocker Dongle (By Legija) | 1 | 03-25-2009 10:40 |
u880 big problem | junior15i | LG | 4 | 06-09-2008 02:16 |
lg u880 unlock problem | burraq | FuriousGold | 4 | 11-07-2007 16:58 |
U880 Big Problem Urgant | gilani4_all | LG | 0 | 08-07-2007 09:00 |
lg u880 network problem and restart after unlock | gopalg73 | LG | 0 | 02-09-2007 14:30 |
