Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG
Old 10-25-2017, 13:25   #1 (permalink)
Member: 2764406
Thanks Meter: 2
Red face Need FRP Solution for LG Q6 M700 Android 7.1.1
I am unable to remove frp lock from LG Q6 M700 Android 7.1.1 device, tried every single method, i am stuck on when i try to install googela cc manager, or frp bypass, or quicshortcut maker, it leads me to "wifi or tethering" options instead of installing option.
that is why i am unable to install these files.
I need expert for these ? or should i upgrade firmare etc.
if upgrade firmware is the solution then guyz give me procedure and link of LG Q6 FIRMWARE and all software links. need helpful answer plz
Old 10-28-2017, 15:11   #2 (permalink)
Member: 2764406
Thanks Meter: 2
Ah! still no reply, i am waiting that someone response me
Old 11-08-2017, 05:08   #3 (permalink)
Member: 98342
Sonork: 1641338
Thanks Meter: 16
i got same problem..no solution till now
The Following User Says Thank You to tfcell For This Useful Post:
Old 11-11-2017, 09:09   #4 (permalink)
Member: 2764406
Thanks Meter: 2
Smile yeah
Keep searching solution, if you find any, dont forget to share with me, if i could find, i would update you
Old 11-12-2017, 05:02   #5 (permalink)
Member: 1025079
Thanks Meter: 254
use professional tool, Problem solved.
Old 11-14-2017, 15:20   #6 (permalink)
Member: 1786955
Thanks Meter: 2
frp
lg q6 frp plz help plz help
Old 11-16-2017, 07:39   #7 (permalink)
Member: 1786955
Thanks Meter: 2
q6 m700 android 7.1.1 frp plz help
i did with umt dong its done but again asking google frp
Old 11-17-2017, 08:57   #8 (permalink)
Member: 2702594
Thanks Meter: 7
me 2 same problem
i try to bypass using quickshortcut maker,bypass app
but in settings its shows only wifi & hotspot option only
is there any another solution
plz frnds help me to unlock it
its urgent
Old 11-21-2017, 21:56   #9 (permalink)
Member: 1581456
Sonork: malkof_001
i have a bypass no full, install the quickshortcut maker and open with a custom launcher, but for full bypass,
could not find the way to enter the settings to install what
is needed for now I can use it but add account and install programs not yet
i used the z3x the process is completed when starting the phone enters without account for 2 seconds and restarted leaving in the same menu add google account
Old 11-22-2017, 18:47   #10 (permalink)
Member: 2764406
Thanks Meter: 2
hey
Originally Posted by Sumanth0707 View Post
me 2 same problem
its urgent
have you got solution? can you enable USB Debugging ?
Old 11-23-2017, 07:47   #11 (permalink)
Member: 2702594
Thanks Meter: 7
I didn't get any solution right now
But in few days. There is a solution
Old 11-26-2017, 18:59   #12 (permalink)
technomak's Avatar
Member: 2035802
Sonork: 100.1675827
Thanks Meter: 173
i am also still waiting for the same
Old 11-29-2017, 13:34   #13 (permalink)
technomak's Avatar
Member: 2035802
Sonork: 100.1675827
Thanks Meter: 173
I tried in all available dongles like Octoplus,UMT, Chimera tool but all are fail
If anyone got the FRP bypass method of lg q6 pls post successful story
Old 12-13-2017, 18:55   #14 (permalink)
Member: 2764406
Thanks Meter: 2
Very sad that, still this has not frp solution please update here if anyone of you could find frp solution of this device
The Following User Says Thank You to jamesalbert33 For This Useful Post:
Old 12-23-2017, 09:52   #15 (permalink)
Member: 2585849
Thanks Meter: 3
i have one if you have z3x lg tool
use your brian or contact me
Page generated in 0.38455 seconds with 7 queries
