10-15-2013, 23:05 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bamako Mali
Member: 1803689 Status: Offline Sonork: 100.1659873 Thanks Meter: 154 | LG GT 400 problem i tried to unlock it but wihtout sucess. Now i flashed it with SETOOL3 with a firmware download on SETOOL3 support. And since that phone work fine without SIM CARD,when i inserted a SIM card it said me USIM LOCKED. when flashing with setool i check UNLOCK DURING FLASH PROCEDURE. Here is log SIGNED MODE (USING SERVER) CFG:100100000000 ChipID: D900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803086389] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35982803086389 CERT:RED LDR: CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL2 LDR CAPS: SYSTEM FLASH SIGNATURE LDR: MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_SETOOL2 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM writing "D:\Documents and Settings\USER\Mes documents\Téléchargements\BIN_GT400AT-01-V10a-208-20-APR-08-2010+0\GT40x_cxc000000_APPLICATION_PHONE_SB_IAR-ARM-NAND.ssw" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 54 Will flash 619 blocks ... SSW file accepted writing "D:\Documents and Settings\USER\Mes documents\Téléchargements\BIN_GT400AT-01-V10a-208-20-APR-08-2010+0\GT40x_CXC_LGPXO_SYS_CABS_LP_NAND_commercial .ssw" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 54 Will flash 325 blocks ... SSW file accepted writing "D:\Documents and Settings\USER\Mes documents\Téléchargements\BIN_GT400AT-01-V10a-208-20-APR-08-2010+0\GT400_CXC_FS_CABS_LP_NAND_commercial_BYT_FR .ssw" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 54 Will flash 1554 blocks ... SSW file accepted Elapsed: 621 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID: D900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803086389] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35982803086389 CERT:RED LDR: CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL2 LDR CAPS: SYSTEM FLASH SIGNATURE LDR: MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_SETOOL2 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS ... A2_eraseSecData,err details:00000064 Unlock FAILED Elapsed: 16 secs. thanks to all |
10-16-2013, 14:30 | #2 (permalink) |
Member: 1803689 Status: Offline Sonork: 100.1659873 Thanks Meter: 154 | finally solved with LGtool from SETOOL Here is log Connecting with GT400 Warning: For proper work, battery must be fully charged Reconnect battery, press and hold volume up button, connect cable to the phone If phone is not connecting, solder testpoint Port opened, waiting for phone ping... CPU: DB3200 P3A/R3A Ericcson Mobile Platform: v4.1 Chip Class: 0x00020000 Fuse Locks: RETAIL SECURITY Security Domain (Color): RED (retail) OTP Lock: Locked OTP CID: 54 OTP PAF: 0 OTP IMEI: 35982803086389900 Flash CID: 54 Flash PAF: 0 IMEI: 359828-03-086389-9-00 Effective CID: 54 Effective PAF: 0 Sending ACC Preloader Sending APP Preloader Sending ACC Loader Sending APP Loader Connected Unlocking phone Unlocking phone Phone unlocked succesfully Phone successfully unlocked Disconnected |
