05-30-2007, 15:46 | #12 (permalink) |
Freak Poster Join Date: Dec 2004 Location: TETOVO Age: 46
Member: 98757 Status: Offline Thanks Meter: 3 | i have same problem i can solve it is not flex cable i change software keypad dosnt whork i think some ic is bad but i dont knowh which ic is for keypad help me |
05-30-2007, 18:58 | #13 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 237646 Status: Offline Thanks Meter: 19 | try and change the LG KG800 Chocolate FLEX RIBBON CABLE screen problems? Then consider changing the Flexi PCB (ribbon). This is a common failure as the ribbon can suffer wear as the phone slider opens and shuts. Eventually the ribbons become worn and often this results in a screen failure. Changing the ribbon can cure this in most cases... We advise that a new ribbon is added when the screen is changed it’s a good way to service this type of part. So if you do have a screen problem including a screen failure then consider changing this part before you spend good money on a screen. This is a LG KG800 Chocolate Flex Ribbon Cable A common fault is the screen going white , this is usually a ribbon problem and can be fixed with replacing this ribbon you can find it here http://www.uk-mobilestore.co.uk/prod...roducts_id=573 |
07-23-2008, 01:02 | #15 (permalink) | |
Insane Poster Join Date: Dec 2004 Age: 60
Member: 95352 Status: Offline Thanks Meter: 3 | Quote:
What now ? | |
HOW TO unlock SE v600i ??please help | xiongfuchen | SETool2 | 15 | 05-21-2013 08:10 |
please help me to unlock N97 [ANSWERED] | longgiang81 | Genie Universal | 2 | 03-30-2010 09:18 |
Please Help Kg800 | Jovan29 | LG | 2 | 11-14-2006 12:35 |
Please Help Kg800 | Jovan29 | LG | 0 | 11-14-2006 11:35 |
