01-28-2010, 06:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | problem entering unlock code to kf240 all folders are empty, I dont see any choice for entering NCK, I tried with non accepted Sim and without Sim also... any idea? should I try flashing the phone? it is kf240 locked to digitel venezuela |
01-28-2010, 07:36 | #2 (permalink) |
No Life Poster Join Date: Mar 2004 Location: LGE
Member: 57760 Status: Offline Sonork: 100.1579298 Thanks Meter: 3,510 | Try this 1. Insert a not accepted SIM Card and turn ON your LG KF240. 2. Your LG KF240 will display "phone restricted". 3. Select Cancel 4. Your LG KF240 will display "phone restriction code". 5. Enter the Unlock CODE 6. Select OK |
01-31-2010, 02:05 | #3 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | No bro, with non accepted sim it says: Insert Correct Sim Card And only SOS button is available... Any idea pls? how can I flash this set free? any firmware and dll available fro gsmulti3 ? |
11-05-2010, 23:44 | #5 (permalink) |
Junior Member Join Date: Nov 2010 Location: Maturin, Venezuela
Member: 1433691 Status: Offline Thanks Meter: 4 | ok, with original sim, enter this code: 2945#*71001# Then, you should go: Menu Settings > Security > Sim Unlock (in my phone all is spanish) I hope to be helpful... Last edited by jrcsdev; 11-05-2010 at 23:45. Reason: add info |
11-06-2010, 00:20 | #6 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: ALGERIEN
Member: 19423 Status: Offline Sonork: 69566 Thanks Meter: 246 | Quote:
good chance br maya 3845#*240# | |
11-06-2010, 03:31 | #7 (permalink) |
Member: 1433691 Status: Offline Thanks Meter: 4 | Oye, el tambien esta bloqueado por digitel de venezuela, yo todavia no tengo el codigo de desbloqueo. Para desbloquearlo debes hacer esto: En la pantalla principal, con la sim de digitel teclea el siguiente código: 2945#*71001# Aparentemente no pasa nada, pero se activo un menú secreto. Luego anda al menu Configuraciones > Seguridad > Bloqueos SIM > Red > Desactivar Allí te va a solicitar el código. En serio pruébalo, yo tengo este teléfono en venezuela... más bien me gustaria tener el código jeje |
11-16-2010, 13:40 | #10 (permalink) |
Crazy Poster Join Date: Feb 2008 Location: india Age: 46
Member: 696199 Status: Offline Thanks Meter: 3 | check this link all lg enter lock code solution is here How to enter the LG Unlock code into your LG Phone Enjoy............ use thanks button |
how to enter unlock code to amoi wp-s1 (3G Skype phone) | artur223 | UnlockBase | 6 | 09-17-2008 04:34 |
how to enter unlock code to amoi wp-s1 (3G Skype phone) | artur223 | Phone Unlocking Codes & Maps | 21 | 03-18-2008 14:30 |
HOW TO ENTER UNLOCK CODES TO NEC 411i ;Nec 500i;....? | Eagle7 | FuriousGold | 3 | 01-04-2008 12:34 |
how to enter unlock code to blackbarry 7100g | wiliam | FuriousGold | 1 | 11-29-2006 21:53 |
