06-27-2006, 22:26 | #3 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Salvador - Bahia - Brazil Age: 48
Member: 172567 Status: Offline Thanks Meter: 90 | Search in the forum, free solution is in there. There's vygis cracked to unlock and flash the phone, and in your case, they sugest to relock the phone with vygis software and then unlock it with vygis again: it will repair your GDFS. You'll need the serial cable with battery attached, if you wanna make it in the same threads you'll find the scheme. |
06-27-2006, 22:45 | #4 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: Romānia
Member: 76629 Status: Offline Thanks Meter: 76 | Quote:
U can use Vygis cracked, too! U will find Repair_FullFlash for 8130, on the vygis site (U will need login and password, so U must be Vygis customer) or U can find somewhere in this forum! I you'll be smart enough, you will find the original repairflash from vygis for free! Good luck in searching! HWK S_u_c_k_s! | |
06-28-2006, 14:51 | #5 (permalink) |
Member: 172567 Status: Offline Thanks Meter: 90 | Don't trust in HWK and clips for LG 3g, normally they unlock modifying gdfs, and in this cellphones is normal to have failures. Vygis don't replace gdfs, it becomes safety for your cellphone |
Problem with LG KE850 after flashed it, with Polar II. ::: ANSWERED ::: | Grupo MovilFree | PolarBox 3 | 10 | 02-26-2009 10:21 |
Help with Lg 8130 | nidhal1981 | LG | 3 | 05-27-2006 15:01 |
Strange problem with LG 8130 | faly99 | Redbox | 2 | 10-15-2005 13:22 |
i have a problem with lg 8120 unlocked with setool2 | OvidelGSM | Twisterflasher | 1 | 03-28-2005 11:40 |
Problem with LG B1200 | mr_x4you | LG | 2 | 04-23-2003 06:59 |
