Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > LG
Old 02-05-2004, 20:30   #1 (permalink)
Member: 52242
Question problems with G7100 and sms
Hi all
I have a problem with my new phone G7100 the problem is that every time i turn it off an back on it displays ( network error ) when i try to send a sms message, i have to confirm sms settings ( wiht out chaning any of them ) for this problem to stop.
I know its not my SIM card because it works fine in ohter phones, and not the firmware because i opgrated ( form V103 to V116 ) it and it didnīt fix the problem
hope someone can help me
THANK YOU
Old 02-07-2004, 16:46   #2 (permalink)
Member: 52718
Originally Posted by Wolfman LG
Hi all
THANK YOU
So the problem is still on the latest SW? I have the same problem on mine and thought it would be solved with this new SW. Atleast a techician told me it would help..Then I will not send it for SW update then..
Old 02-07-2004, 16:53   #3 (permalink)
Bomber's Avatar
Member: 1756
try factory reset, 2945#*#
Old 02-07-2004, 17:25   #4 (permalink)
Member: 52718
Will that solve that bug? Is the tuning settings set to factory settings to? Cause doing a factory reset on Nokia phones makes the tuning go bad on some models.
How can I check my Firmware?
Old 02-07-2004, 23:37   #5 (permalink)
Member: 6781
mannnnn please when you reflash your phone ...please check box for OWCD....and everything is going to be solved...you do not need "new software"....mannnn
Old 02-09-2004, 19:14   #6 (permalink)
Member: 52242
that didnīt work
thank you for your input but the OWCD didnīt solve the problem.
Old 02-10-2004, 17:07   #7 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Cool
Reset Factory setting, doesn't change any network tunning and something else,
it just do FACTORY SETTING, everything user changed will getback to first setting,
also about freezing in sms and else, new firmware is the best solution till now
also RESET FACTORY SETTING should help , sometimes too
OWCD = OverWrite Calibration DATA
if you translate it to your language, then you will see it's so dangerous if you check the box
( Loosing Network, and IMEI, EEPROM change )
Old 02-10-2004, 20:08   #8 (permalink)
Member: 52718
Thanks! How do they flash the LG phones? Do they use a securitybox or dongle like nokia FPS-8? Or are anyone able to do it with the right SW?
I think Iīll try a factory reset then.. problem is I dont wanna put all the data iīve stored back into it by hand again..
So the OWCD on LG is like the Factory Default on Nokia then..
I repaired Nokia for 8 years. But recently quit for new advantures
Old 02-11-2004, 12:12   #9 (permalink)
Member: 6781
of course it is dangerous to rewrite calibration data.....but if you can redone calibration....it is no problem....but if it is problem in that sector you must try to rewrite....there is no solution.....if you decalibrate your phone...of course good eqiped service sould have equip for calibration.....
btw...there is box for LG and evry authorized service have it....it iz box for changing software....and also for calibration....wery wery *** device
Old 02-12-2004, 19:28   #10 (permalink)
Member: 52718
factory reset
I havent tried this factory reset yet. But since the problem existed from the first day I dont think that will solve it? These kind of resets normally works when you have installed alot of things in the phone and just like on computers the f**k up after a while..
Do everybody have this sms "network error" problem after restart?
Old 02-13-2004, 15:58   #11 (permalink)
Member: 52718
Hi guys! I tried the factory reset without any succes
I have V 1.03 in it. Is this fault fixed in the new Firmware V 1.16?
Old 02-14-2004, 22:49   #12 (permalink)
hakima's Avatar
Member: 33804
Pls try to flash your phone with this Version and post!!!
For me this solution is good!!!
Problem with HWK and UFSx3 all orginal and not work what to do ?????? wgmmmx HWK 5 04-01-2008 22:18
Problem With 5200 And 5300 Unlocking With Free Method strangerboy MT-BOX 52 09-13-2007 15:35
Problem with SETool and IMEI with w550 Bohosh Sony Ericsson 4 01-14-2006 09:57
SS T208 problem with send and receive SMS zerocool09 VLSI, Conexant, Skyworks and Old Models 0 05-13-2003 18:19
Page generated in 0.41625 seconds with 11 queries
