Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG
Old 02-16-2006, 22:25   #1 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
U8120 blink.- after flash no display
hi
I resive U8120/ It show logo for feu second, then becklite off and on screen appers "data pdk PhoneMngr.pxe" and somethyng like memory dump.Phone hang. Using smartBox I flash (all4 file) it using v107 flash. Phone work, but big LCD is wite and small shift image to right. I try v104 and v101 but same problem. Pleas help me. I can`t belive thet flat cabel is ded after reflash...
Old 02-16-2006, 22:31   #2 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,588
try with other Flash files ( better downlad all version) if not succed try to write FULL GDFS
Old 02-16-2006, 23:03   #3 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
now try use wygis and v102 full flash - same result
Old 02-16-2006, 23:25   #4 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,588
you need to have good GDFS from other working phone
Old 02-17-2006, 00:34   #5 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
You thynk, full not include GDGS? Olso, then I flash all 4 file using Smart Box GDFS is not toched? So, explane me, hove to flash GDFS using smartBox and if can, share to me good GDFS flash Thenks
Old 02-17-2006, 08:40   #6 (permalink)
parveen kumar's Avatar
Member: 145241
Thanks Meter: 26
hi
just only unlock on hwk.problem is solved 100%.
Old 02-17-2006, 09:56   #7 (permalink)
shohag's Avatar
Member: 147116
Sonork: 100.1578260
Thanks Meter: 316
u need 100% GDFS.....
work it 100%...........
Old 02-17-2006, 10:56   #8 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
try one, but not help
Can somebody share me 100% working U8120 GDFS for Vygis, pleas?
Old 02-17-2006, 10:59   #9 (permalink)
delta master's Avatar
Member: 159640
do u have cruiser.then you can download the gdfs from the webside and flash it with cruiser it works 100% because i have this problem before.
Old 02-17-2006, 11:01   #10 (permalink)
Member: 11647
Thanks Meter: 26
@Porter
try here
LG3G GDFS and Unlock Files, Download here
Old 02-17-2006, 12:15   #11 (permalink)
gecata's Avatar
Member: 16994
Thanks Meter: 157
Use SeTool and make these steps. Working for me everytime.
1. Press recovery
2. Vrite gdfs
3. Press unlock
4. Make fullflash
Old 02-17-2006, 16:12   #12 (permalink)
bad_signal's Avatar
Member: 107069
Thanks Meter: 31
man u have to reset ur phone to the factory setting
because that phone after flash can't remember the all things that the phone memorey have
Old 02-21-2006, 20:26   #13 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
In my case in U8120 was bord from U8130! I flash it using U8130 flash and all work perfect now!
Regards.
Old 02-23-2006, 10:32   #14 (permalink)
Member: 145241
Thanks Meter: 26
hi
full flash with vygis crack,with bif.format & then rewrite gdfs.phone is 100%.o.k.
V3 after flash no display 5rrrrr Smart-Clip 7 07-13-2006 08:06
2 Motorola V3 after flash no display and keyb light!!!! midou01 Smart-Clip 18 01-10-2006 16:43
Philips 350 after flash no display AndRe DCF-gsm Redbox 1 07-08-2005 00:39
n gage after flash no display plz help surat1 WD2 & APE (Symbian Phones) 2 04-04-2005 06:13
t100 after flashing no display s4sajii Sony Ericsson 7 11-04-2003 15:48
Page generated in 0.43690 seconds with 8 queries
