Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > LG
Old 04-07-2006, 12:44   #1 (permalink)
mihaser's Avatar
Member: 112820
Question U8380 -- camera not working. [resource not found]
I flashed u8380 v10a. Unlocked it. Everything was fine. On the next day client returned me the phone with problem like in title - [resource not found]. I flashed it again, but stil same error.
What`s to do?
Old 04-07-2006, 13:08   #2 (permalink)
Bypx's Avatar
Member: 62336
Which tool you've used for unlocking? Are you sure the camera was working before?
Old 04-08-2006, 12:16   #3 (permalink)
mihaser's Avatar
Member: 112820
I`m used Cruiser and Vygis for flash langpack.
I didn`t test camera before.
In service menu > camera test > vga camera is working, but 1.3M not working.
Old 04-08-2006, 12:49   #4 (permalink)
Member: 127269
Sonork: 100.1605945
Flash all 4 files by using Cruiser & ur set will alright
Old 04-08-2006, 12:51   #5 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
See conector for camera on flat cable,it is not software problem.I had simular problem on one 8360 which was filled with super glue around camera conector and after cleanup it was not giving resource not found but camera was still not working and I returned.I guess that flat was damadged or camera module,didn't had the chance to discover it
Old 07-06-2007, 21:34   #6 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
Just to inform you that the problem is in flat cable.i got one 8380 with half display showing,after change flat cable it was showing "resource not found",so I changed another new one and was the same,but after changing all parts from original flat cable to the new one the camera was working great,the 1.3 megapixel and the vga,hope will help you and others with simular problems,
regards
Old 08-03-2007, 00:23   #7 (permalink)
Member: 559210
I have the same problem, but i don't think that it is a hardware problem... i had already checked all stuff around. I've changed my LG's Phone flat cable, checked all parts, but I didn't solve the problem. For the both cameras - "Resource not found" . I am a home user, so I have just my USB Data Cable and my CD. Do I have a chance to try make it work, until I get to a service? Should I try something? I've already done the test by the service menu... but the cameras aren't workin'...
Old 08-03-2007, 05:19   #8 (permalink)
Temporary banned !!
Member: 546766
it is hardware problem
at first change the camera
thankkssss
Old 08-03-2007, 06:44   #9 (permalink)
UNIQUEM's Avatar
Member: 496203
Sonork: 100.1583640
mybe help you
you shuld flash it on setool you problem will sole but i think its cameras strip prob
Old 08-03-2007, 06:54   #10 (permalink)
i_am_rocky's Avatar
Member: 64311
101% camera problem ..also this may be flex problem...remove and replace all parts from new flex to old tested by me
6300 CAMERA (sometimes works, sometimes not working) akadhitz Nokia Base Band 5 ( BB-5 ) 3 02-19-2010 09:31
My box is "dead". Show only "." and not working. Update not working! GSMtricks Multi-Box 1 12-09-2008 20:04
new solutio for My box is "dead". Show only "." and not working. Update not working wadjayy Multi-Box 1 09-10-2008 03:06
My box is "dead". Show only "8" and not working. Update not working! MobiLuy.co.yu Multi-Box 11 08-22-2007 07:52
cdr2 not working device not found mobilerepair1 SagMaster Team OLD Products 0 08-10-2005 12:29
Page generated in 0.30167 seconds with 11 queries
