Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Java, iOS, Android, Symbian development
Java, iOS, Android, Symbian development No SIS,JAVA,IPA Files to download here, this section is created to those who are Interesting in Programming JAVA,Android,iOS or Symbian Applications.
Old 06-27-2014, 11:06   #1 (permalink)
ch wajid's Avatar
Member: 2203737
Sonork: 1656500
Thanks Meter: 462
micro sd memory card unlocker software
I Need micro sd memory card unlocker software
Old 06-27-2014, 12:54   #2 (permalink)
Cheater -Don't Deal with him-
Member: 1390802
Thanks Meter: 1,101
this solution have support in atf box.
The Following 4 Users Say Thank You to ..::MOBILEPARK::.. For This Useful Post:
Old 06-29-2014, 16:42   #3 (permalink)
Member: 1860537
Sonork: 1657411
Thanks Meter: 39
try to nokia c6, 5233, 5800, insert memory then format your memory will erased
The Following User Says Thank You to viruscare For This Useful Post:
Old 06-29-2014, 19:14   #4 (permalink)
Member: 2035269
Thanks Meter: 23
atf box is da best read card inform and format very easy
Old 06-30-2014, 16:36   #5 (permalink)
Member: 2198466
you can format the memory card and recover that with GetDataBack For Fat
Old 07-01-2014, 05:51   #6 (permalink)
Thanks Meter: 4,183
i need micro sd memory card unlocker software for pc
Old 07-01-2014, 06:47   #7 (permalink)
Member: 1126941
Sonork: 100.1672154
Thanks Meter: 2,488
there is 2 ways to unlock ....
1st use nokia s60v5 series mobile like 5233, 5800, e71, n8
and format ur memory card...automatic its unlock
2nd use ATF box to unlock
The Following 2 Users Say Thank You to mobi_soft For This Useful Post:
Old 07-03-2014, 10:57   #8 (permalink)
Member: 2211471
Sonork: 100.86843
Thanks Meter: 2
about of sd card unlock solution
plz buy in magic card reder only 150/- all memory card unlock and recovery
Old 07-03-2014, 14:20   #9 (permalink)
Ahmadaim1's Avatar
Member: 2165294
Thanks Meter: 59
Pls is any one with memorycard unlock software
Sent from my Nokia_X using Tapatalk
Old 07-03-2014, 16:39   #10 (permalink)
Member: 1390802
Thanks Meter: 1,101
this device available in market for unlock any mmc card..
http://www.cs-tele.com/product-image...nlock-Clip.gif
http://img.dxcdn.com/productimages/sku_6702_1.jpg
Old 07-10-2014, 18:20   #11 (permalink)
Member: 1305225
Thanks Meter: 30
need software not the box........................which can formatte the memory card which says .> memory use in another application
Old 07-10-2014, 18:26   #12 (permalink)
Member: 1306485
Thanks Meter: 9
use s60 series card reader or s60 series mobile
isme kisi softwear ki jaroorat nai padhegi
Old 07-11-2014, 16:08   #13 (permalink)
Member: 2220621
I think you should have best results using nokia s60
Old 07-14-2014, 14:10   #14 (permalink)
Member: 1021853
Thanks Meter: 27
gpg mmc unlocker .
Old 08-22-2014, 19:28   #15 (permalink)
Member: 2244402
Thanks Meter: 2
what will you get when u unlock micro sd card ? i mean how its locked ? really dont understand
[IMG] code is Off
Page generated in 0.20243 seconds with 8 queries
