Java, iOS, Android, Symbian development No SIS,JAVA,IPA Files to download here, this section is created to those who are Interesting in Programming JAVA,Android,iOS or Symbian Applications. |
05-14-2011, 16:27 | #1 (permalink) |
Junior Member Join Date: May 2011
Member: 1574817 Status: Offline Thanks Meter: 0 | Smart Data Recovery 4.4 - Recover All YOUR Deleted FILES! http://i51.photobucket.com/albums/f3...a_Recovery.jpg Info: Smart Data Recovery is a data recovery tool for Windows operating system that supports the FAT and NTFS file systems.The Data Recovery is an effective and powerful, easy-to-use software program that enables the recovery of lost data. Smart Data Recovery is compatible with almost all kinds of data storage - from computer hard drives to digital cameras. It also supports flash drives, USB drives, floppy disks, memory sticks, PC cards, multimedia cards, and secure digital cards. The Data Recovery is able to restore all sorts of files, including electronic documents and pictures. It restores files from FAT32 and NTFS hard drives, has really simple interface and is compatible with Windows operations systems. Our aim is to prevent information loss, and prevent you from wasting your time and money. For different reasons, important documents and user files are sometimes lost. Without a recovery tool for documents and files, this may become a huge problem (one that leads to considerable inconveniences, and requires expensive solutions). Smart Data Recovery applies a simple yet powerful algorithm, which makes it possible to restore your lost data quickly and effectively. The Data Recovery can recover any deleted files, including MS Office files, images, mp3, and zip files! Recovering data lost due to system malfunction or user error requires hours of work preceded by hours of research from unsuspecting victims. Educate yourself about possible ways to recover data from damaged disks and corrupted flash memory cards before the failure happens. While there is no lack of data recovery tools on the market, downloading and trying one after another is the worst idea ever. A badly executed unsuccessful attempt to recover lost files can and does cause irreparable damage to corrupted data. How would you choose the right data recovery tool to do the job? There are several criteria to data recovery software that you should be aware of. First, there are tools designed to recover your files and data, such as Office documents, archives, pictures and other stuff, and there are tools that repair the damaged disk structures such as the file system (FAT or NTFS), MBR and partition table. Note that the second class of recovery tools cares little about what happens to your data, often messing up with your files while repairing the damaged system structures. Second, if you are new to data recovery, you need a tool that is as easy to use as possible. You don't want data recovery tools advertised as 'professional', as only the real professionals can benefit from using those. Let us be honest: you're more likely to screw things up with these tools as they deliberately lack any protection against possibly disruptive actions on your side. Third, get only those tools that can demonstrate their ability to recover data instead of taking their word on it. Smart Data Recovery by Smart PC Solutions is a perfect solution for rush data recovery. If you have no specialized experience in data recovery, but need your data back right away with no risk, Smart Data Recovery is an ideal tool for you. Fixing your files and recovering your data, Smart Data Recovery is designed as a fully fool-proof solution. A simple step-by-step wizard guides you through the recovery process, asking you questions that are easy to understand and to answer, such as asking you to pick a disk that contains files to recover. To make things run even smoother, Smart Data Recovery has a U3/USB edition that runs from a flash memory card, minimizing unnecessary writes to the damaged disk. Smart Data Recovery can often recover files even if your disk has been reformatted (on FAT formatted disks). Smart Data Recovery can recover data from disks formatted with all versions of FAT or NTFS. The pre-recovery preview demonstrates you exactly what the recovered file will look like, making you sure that the recovery is actually possible. Don't take our word on it! Compatible Platforms: Windows NT/2000/XP/2003/Vista/Windows® 7 Download: Code: http://rapidshare-filese.com/vault/040310/downloads/1SDr-4.4.zip.html GetData Recover My Files v4.6.6.830 Professional http://i51.photobucket.com/albums/f3...vermyfiles.jpg Info: Recover deleted files emptied from the recycle bin or deleted due to a virus infection, the format of a hard drive or software crash. Recover My Files data recovery software will easily recover deleted files emptied from the Windows Recycle Bin, or lost due to the format or corruption of a hard drive, virus or Trojan infection, unexpected system shutdown or software failure. It has full options to search Windows temporary folders and can even locate and recover files that have never been saved! Recover My Files data recovery software requires no special technical skill. Recover My Files is fast and easy. No technical or data recovery software skills are required to undelete files. Use Recover My Files to perform hard drive data recovery, or if you are trying to unformat and recover data from floppy disk, zip drive, smart media, compact flash or other removable media. It is easy disk recovery software to undelete files and get data back. Recover My Files data recovery software will find any type of file, but includes specific support for more than 300 file types in the following broad categories: . Recover deleted email . Recover deleted documents . Recover deleted archives . Digital Photo recovery . Recover deleted music and video Recover My Files is compatible with Windows 98/ME/2000/2003/XP and Vista and works with FAT 12, FAT 16, FAT 32, NTFS and NTFS5 file-systems. With a deleted file the data content of the file is rarely destroyed. Even if Windows file reference information has been destroyed, Recover My Files scans the data at a low level to locate "Lost Files" by their internal file structure. This allows Recover My Files to recover deleted files that other data recovery software can never know exist. Professional data recovery software for: . Deleted Files; . Lost Files; . Formatted Disks; . RAW Disks; . Missing Drive Letters; . Windows Reinstalls. Safe, secure and reliable. Designed specifically to allow home and business users to quickly and simply recover data. Simple to use, with a full file preview window for recovered files. Recover My Files is the perfect recovery tool for: . Hard drives . USB drives . External storage units . Digital camera storage media . CDs and DVDs Recover My Files V4 supports recovery from a wide range of Filesystems: . FAT16 - an early version of the FAT Filesystem, now rarely used . FAT32 - common for external storage media and digital camera equipment . exFAT - (Extended File Allocation Table), a proprietary file system suited especially for flash drives . GPT - GUID Partition Table, a standard for the layout of the partition table on a physical hard disk . NTFS - Standard files system for Windows Vista, Windows 7 . CDFS - CD/DVD file systems (Coming Soon) . MAC - HFS (Coming Soon) . EXT2 - Linux (Coming Soon) . RAID - RAID JBOD, 0, 1, 5, hardware and software Download: Code: http://rapidshare-filese.com/vault/040310/downloads/31f33.html Link checked on 10 May 2011 |
05-15-2011, 11:47 | #2 (permalink) |
Junior Member Join Date: Feb 2011 Location: New York
Member: 1522340 Status: Offline Sonork: Jeriff Cheng Thanks Meter: 1 | I think nice to Recover Data for Mac is more powerful than this software.It supports Photo Recovery,Deleted File Recovery, Lost Partition Recovery and Deep Scan Recovery |
08-16-2011, 06:38 | #3 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1423501 Status: Offline Thanks Meter: 0 | I've deleted a bunch of photos which were just taken today and really need them back. I have a Nokia 6500 Classic and connected it to my Laptop highlighted and dragged all the images (including the ones I needed and thought were highlighted) into another folder but it turns out they were not highlighted and are now deleted off the phone and are not in my Recycle Bin. Help!?undelete files |
02-03-2012, 11:17 | #5 (permalink) |
Junior Member Join Date: Feb 2012
Member: 1718118 Status: Offline Thanks Meter: 0 | Recover All YOUR Deleted FILES from memory card! Hi, The only way to recover deleted photos from sd card is by using recovery software. First, remove your memory card from the digital camera then connect it to computer using card reader to recover deleted pictures using recovery software. I have used memory card recovery software to recover accidentally deleted pictures from my Canon camera. This software supports different brands of digital cameras like Canon, Nikon, Olympus, Fuji film etc. Different file formats can be recognized and recovered on the basis of their unique signature. Accidentally formatted or reformatted memory cards can also be recovered quickly. You can download free demo version of this software and check for the recovery results. |
02-23-2013, 07:10 | #7 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1888755 Status: Offline Thanks Meter: 0 | It is very easy to recover all the lost, corrupted and deleted images and all the files from the storage device with the help of Automatic Recover Tool. It is highly advanced and does the recovery very easily and effectively. It show the preview of the recoverable data file. For more information, you can visit : Recover Your Corrupted Digital Photos By Photo Recovery Software | Digital Photo Recovery |
02-26-2013, 12:10 | #9 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1862687 Status: Offline Thanks Meter: 0 | Today there are many data recovery software are available for recovering deleted, corrupted, damaged and lost items, which makes the data recovery process is much easier and safer. But we suggest you to go with only that application which is especially made for recovering the lost data from the digital devices. You can use an automatic file recovery for Mac software which supports to recover your lost data from different types of storage media including hard disk drive, memory card, pen drives, smartphone, camcorders, camera and many of other digital devices. For more information about how to recover the lost data you can visit : How To Undelete Mac Files After Accidental Formatting | File Recovery Mac To get more help you can visit other thread where you can get related information about data recovery process: http://forum.gsmhosting.com/vbb/f162...t=mac+recovery |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
