Java, iOS, Android, Symbian development No SIS,JAVA,IPA Files to download here, this section is created to those who are Interesting in Programming JAVA,Android,iOS or Symbian Applications. |
09-20-2010, 09:58 | #1 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1392420 Status: Offline Thanks Meter: 10 | Phase One Capture One PRO v5.2.41190 Multilingual http://img411.imageshack.us/img411/7310/334osvl.jpg Phase One Capture One PRO v5.2.41190 Multilingual | 122 Mb Capture One uses the concept of 'Collections' to group images together, in the example shown below this happens to be images in a particular folder, although in reality images from various sources can be grouped into a collection. The default layout has the collection pane (thumbnails) on the left, preview / work pane in the center and function tabs on the right. All panes can be resized or collapsed, you can also work in full screen mode without a titlebar. The one big strength Capture One DSLR has over the Canon software is that all adjustments happen in (almost) realtime. That means you can make a grey balance adjustment and see the change immediately, this is far better than the rather slow-to-change Canon FIle Image Viewer. You can alternatively switch to a horizontal view (press F8) which shifts the collection pane to the bottom of the window. This is probably a more useful layout for landscape photography. Color Management and Preferences Globally you can set various preferences including full color management support. Capture One DSLR comes provided with profiles for the EOS-1D and EOS-1Ds under various light conditions. You can also select destination color profiles for output, web and proof destinations as well as your monitor profile. There are also a wide range of preferences to choose from, click on the reduced image below to see them in more detail. Operation and Workflow Operationally you can work on previous shot and stored images or capture directly from the camera 'into' a collection live in the Capture One DSLR application. This feature wasn't tested at this stage. As you change settings such as color balance, sharpening etc. these are stored by Capture One in its own database (remembered on a per image basis). These settings can be saved and loaded as well as applied to selected images, a batch 'development' or an entire collection. Settings are arranged into three of the five function tabs on the function pane, each function pane is described below. Output Below you will find two versions of the same EOS-1Ds RAW image output as JPEG from both Capture One DSLR and Canon's own File Viewer Utility. Remember that Capture One DSLR is still in its Beta form and thus image quality and performance may not be true to the final version. I do like the overall tonal balance and color response of the Capture One DSLR image, very nice. Download Code: http://hotfile.com/links/70597252/4235ac9/nbe-media.com_Phase.One.Capture.One.PRO.v5.2.41190.Multilingual.Cracked-EAT.rar.html |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
