Java, iOS, Android, Symbian development No SIS,JAVA,IPA Files to download here, this section is created to those who are Interesting in Programming JAVA,Android,iOS or Symbian Applications. |
08-18-2004, 22:54 | #1 (permalink) |
Junior Member Join Date: Oct 2003
Member: 42877 Status: Offline Thanks Meter: 0 | Problems making a connection as a thread I'm finishing my app and i have a pair of new problems. As i've seen in tutorials and other apps i use a main class who implements the midlet interface and the other screens are soons of Form, Canvas, List,... being the main class the one who decide which one is the current screen. But i have 2 problems. How can i show an alert form a not main class? I want to download some images from a not main class, and the class who makes the conection must be a thread, so i've made a method in the main class how returns the byte[] with the data, this method runs the thread and show a Canvas class how inform to the user that the app is connecting and permit to the user cancel the connection but here the problem. I don't know how to return to the Form class the byte[] with the data. Sorry for my bad english and i hope u could answer my question. If u don't understand something or have any problem i'll try to explain it better Thanks Adrián |
08-24-2004, 08:56 | #2 (permalink) |
Junior Member Join Date: Mar 2004 Age: 44
Member: 57585 Status: Offline Thanks Meter: 0 | To show an Alert or any other Displayable you need a reference to the display object, and optionaly a reference to the next Displayable object. You can pass them to the "non main class" by its constructor/set method/... To return the images use a Vector of byte[] inside the Runnable class, and an indicator that check if the imageas downloaded. Code: class MyProgressCanvas extends Canvas implements Runnable { public boolean running = false; public Vector result = new Vector(); private String[] imageURLs = {"...","...",...}; private boolean interrupted = false; void run() { running = true; index = 0; while (index < imageURLs.length) && (!interrupted) { // create new byte[] // download image to the byte array // add array to the vector // update the progress bar or whatever and repaint index++; } running = false; } void paint (Graphics g) { // paint whatever you want } void keyPressed(int keyCode) { // set interrupted to false at certain keypress } } |
Problem with CYCLONE BOX It connects As Boot-laoder Mode But doesnt change Mode... | malikzahidawan | Cyclonebox | 3 | 09-06-2009 22:22 |
problem when try to make sx4 connection | alfares2007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 05-25-2009 05:10 |
Mapping USB active sync connection as Packet/cellular data connection | mujeeb | HTC & PDA WM( With Touchscreen) | 0 | 04-30-2009 21:19 |
can't make replay / post in this thread | GsmTracer | Board, Server and Login Problems/Support | 0 | 05-21-2008 21:30 |
Please make an new DB2020 unlocking thread - be a moron! | m_dige | Cruiser Suite | 2 | 05-12-2007 19:23 |
