Go Back   GSM-Forum > Non GSM/Mobile Related Forums > CAR Electronics
CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes.
Old 07-09-2011, 12:14   #1 (permalink)
Moderator
shooting@orange's Avatar
Member: 469145
Thanks Meter: 3,708
Audi Concert chip reading...............................
I'm making a Motorola reader but need help..
Motarola MCU
AUDICONCERT TT AUZ1Z3
CODE 0000-1999
7 648 244 380 4B0 035 186DBLAUPUNKTMC68HC705B32 (8925904252)MCUTDA7376B
Need to see how to wire up the radio without removing the chip..
Do you have a video?
Thanks
Shooting
please send to [email protected]
Old 07-09-2011, 20:05   #2 (permalink)
audiozone's Avatar
Member: 901844
Thanks Meter: 213
Hi friend, here is the info, I already made the motorola interface and works fine, the diagram connection for MCU HC05 is this:
The processor is configured as follows:
1.The line GND, pin 41 ,to the PC’s ground.
2.TxD ,pin 52,to RxD of the PC trough MAX
5.RxD, pin 50 ,to TxD of the PC trough MAX
7.RESET ,pin 18, to the RST of the PC trough MAX
9.IRQ, pin 19, trough 10k and the +12V
11.PD4 ,pin 9, is wired to the ground
13.PD3, pin 11, trough a resistance 1k-2k2 to +5V
15.TCAP1, pin 22, trough a resistor 1k-2k2 to +5V(processor’s pin 10)
After system is configured it should be connected to the radio .If all the connections are valid the programmer should signal “active connection”. After connecting the converter verify the voltages on the introduced resistors (5V on pin 11,22,10;
10-11V for the pin 19; 4.5-5V reset impulses on pin 18; 4,5-5 V amplitude impulses for pins 50 and 52)
You could find that the above mentioned pins are sometimes linked direct to the ground and in this case the connections need breaking.
The Following User Says Thank You to audiozone For This Useful Post:
Old 07-10-2011, 21:47   #3 (permalink)
Moderator
Member: 469145
Thanks Meter: 3,708
Do you have any pictures? .. also where is step 3,6,8 etc..?
Old 07-10-2011, 22:00   #4 (permalink)
Moderator
Member: 469145
Thanks Meter: 3,708
Here is the programmer I've built...
How do I connect this up?
Old 07-11-2011, 03:01   #5 (permalink)
audiozone's Avatar
Member: 901844
Thanks Meter: 213
Sorry friend, I copied the steps from a document, some steps are missing: 3,4,6,8,10,12 and 14 but maybe they are not neccesary, I made the connections in that way and works 100%. Here is my interface with the same schema, a little modified by me , I added a socket for easy and fast connection:
My interface
Old 07-11-2011, 07:03   #6 (permalink)
Member: 715303
Thanks Meter: 41
The Following User Says Thank You to mmx64 For This Useful Post:
Old 07-11-2011, 17:17   #7 (permalink)
Moderator
Member: 469145
Thanks Meter: 3,708
All SOLVED thanks to Audiozone ...... 1000 thanks
The Following User Says Thank You to [email protected] For This Useful Post:
Old 07-11-2011, 21:16   #8 (permalink)
audiozone's Avatar
Member: 901844
Thanks Meter: 213
Here is the connection diagram for the HC05:
HC05 Interface connection
And if you need it later here is the Interface connection for HC11 E series (PLCC52):
HC11 E series Interface connection
Old 07-25-2011, 21:39   #9 (permalink)
Moderator
Member: 469145
Thanks Meter: 3,708
I tried this and nothing... I'm using Motorola 6.2..
Any suggestions?
Old 07-25-2011, 21:51   #10 (permalink)
Moderator
Member: 469145
Thanks Meter: 3,708
Also you suggest using 2.2k but diagram says 1-2k ... is this important?
Old 07-25-2011, 23:48   #11 (permalink)
audiozone's Avatar
Member: 901844
Thanks Meter: 213
I used in my interface 2.2k ohms resistors and works fine, maybe the diference is the vcc used, you are using 9 volts and I'm using 12volts. The affected pin is the 19 ( IRQ, ) this pin is connected to the (-- In --) in the programmer interface, this wire goes to 12 volts thru a 2.2k ohms resistor in my programmer interface. I already tested with motocracker 4.3, 6.2 and 7.0.
Old 07-26-2011, 05:36   #12 (permalink)
AkaGura's Avatar
Member: 1037717
Thanks Meter: 976
Any suggestions?
Do not ruin something ...
Take the radio and visit a some master in your city !
One day when accumulated more experience then you can read.
Old 07-26-2011, 06:54   #13 (permalink)
Moderator
Member: 469145
Thanks Meter: 3,708
I'll try with 12v and let you know... thanks 1000 times
Old 07-26-2011, 06:57   #14 (permalink)
Moderator
Member: 469145
Thanks Meter: 3,708
Unessessary post!!
I am the expert in my area... I have one problem with one MCU and you post this!!
Maybe you need to read thread to see story first
Old 07-26-2011, 19:40   #15 (permalink)
Argento7's Avatar
Member: 504871
Thanks Meter: 162
Audiozone: Thanks for sharing your exelent work. Good pictures quality and good explain. I really hope Shooting... can solve your issue soon and post results.
Good luck!
The Following User Says Thank You to Argento7 For This Useful Post:
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
read eeprom write eeprom, what do i need? jonthe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 12-08-2010 05:24
unable to reads phone type.. Rosshire Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-17-2000 15:55
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Page generated in 0.47347 seconds with 9 queries
