CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
07-27-2011, 02:57 | #16 (permalink) | |
No Life Poster Join Date: May 2009 Location: MI6
Member: 1037717 Status: Offline Thanks Meter: 985 | Quote:
07-27-2011, 16:46 | #18 (permalink) |
Member: 1037717 Status: Offline Thanks Meter: 985 | Ok for HC05, but this radio have MC68HC705B32 ... -= CODEDRADIO =- Base navigation I think all the answers in this topic should be for a car radio from the first post here: http://forum.gsmhosting.com/vbb/f179...ading-1305333/ |
07-28-2011, 02:46 | #19 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: ENSENADA, MEXICO Age: 53
Member: 901844 Status: Offline Thanks Meter: 213 | Quote:
Ok, you are right, if you want to read a HC705 you need to connect the pin 9 to +5 volts thru a resistor of 2.2k ohms, not to ground. (PLCC 52). Here is the schema used to built my interface, it's already uploaded many times in this forum: Motocracker schema | |
08-08-2011, 14:48 | #20 (permalink) | |
Moderator Join Date: Mar 2007 Location: WALES
Member: 469145 Status: Offline Thanks Meter: 5,153 | Quote:
08-12-2011, 11:15 | #23 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Reading UK
Member: 493754 Status: Offline Thanks Meter: 629 | if you taken mcu from board you need quartz and 15pf caps on it edges tight to gnd , and mcu must be powered , if you work on radio board , radio needs 2* 12v supply , and quartz depends on soft you use |
The Following User Says Thank You to zlix For This Useful Post: |
08-12-2011, 12:10 | #24 (permalink) |
Member: 469145 Status: Offline Thanks Meter: 5,153 | Still not working.. even tried adding a 4.000mhz christal to 16&17 Here is what happens.. (Video) MEGAUPLOAD - The leading online storage and file delivery service Any help... |
08-18-2011, 19:08 | #25 (permalink) | |
Any help would be appreciated.. | |
08-22-2011, 16:29 | #29 (permalink) | |
1000 thanks friend | |
08-24-2011, 16:43 | #30 (permalink) |
Member: 469145 Status: Offline Thanks Meter: 5,153 | I've now tried removing the MCU and wireing direct to the programmer.. I have tried with and without 4.000mhz Christal with no effect.. Any help would be greatful.. Shooting here is my programmer with chip removed: |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
read eeprom write eeprom, what do i need? | jonthe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 12-08-2010 06:24 |
unable to reads phone type.. | Rosshire | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-17-2000 15:55 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
