CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
09-05-2013, 15:19 | #1 (permalink) |
Junior Member Join Date: Feb 2012
Member: 1725222 Status: Offline Thanks Meter: 0 | bmw Bavaria C Electronic BE0728 I have a problem with bmw radio Bavaria C electronic BE 0728. Radio working well for 7 years... but in this day the display say: X_DK t ò3òò And no CODE. (excuse me but i can not post the real photo..) and i can not enter the code. (I have original code card) I have wait many hours with the radio +12 connect, but noting to do. I have try to reprogram the eeprom code BAW574252.... nothing! I have try to replace the BAW with a new 24c01.... nothing! Anyone can help me to solve this problem? Thanks in advance. Fabiano. |
09-05-2013, 20:28 | #2 (permalink) | |
Moderator Join Date: Mar 2007 Location: WALES
Member: 469145 Status: Offline Thanks Meter: 5,153 | Quote:
You need to take it to someone skilled with the correct tools for this kind of work. wbr | |
03-28-2016, 15:38 | #5 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2552213 Status: Offline Thanks Meter: 0 | Hi, did you solve the problem? I have the same and I think it's a PCB thing. If I unscrew the two screws (they connect two ground points) that holds the front panel to the unit, the LCD has no backlight but the radio works good. As soon as I reconnect them, the keys stop working and I got no sound from the speakers other than a crack every 0.5s. Any tips? Mustekweb have you any idea? I will post the solution if we can work it out as it seems to be very common on this particular unit. Thank you |
03-28-2016, 16:40 | #6 (permalink) | |
wbr | |
03-28-2016, 16:57 | #7 (permalink) |
Member: 2552213 Status: Offline Thanks Meter: 0 | I did not find any other post here and I thought it would be better to se this post instead on making a new one. And seems like in this post there are some knowledgeable people! |
03-28-2016, 19:00 | #9 (permalink) |
Member: 2552213 Status: Offline Thanks Meter: 0 | It does very strange things. I'm not very sure it's the front panel. It's kinda weird, with the two bolts a bit loose, if I wiggle the front the behaviour of the LCD changes. If the LCD is backlighted the keys don't work. But if the LCD is dark, then the keys work. |
