CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
07-25-2008, 22:31 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Town City Age: 54
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Clarion_pu-1633a MCU_EEPROM ? Which one? I need to reprogram it. I have ponyprog. My problem: 1=Which one to read/write between NEC japan 784216BGC107 0024E4018 (76 pins) and TOSHIBA2023C (56 pins) 2= Where to connect wires on those ICs??? Thanks |
07-26-2008, 02:41 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Location: ALGERIA, Tlemcen, Tounane Age: 37
Member: 135039 Status: Offline Thanks Meter: 1,486 | Poste here the dump + the new vin for the car where the radio will be installed ! |
The Following User Says Thank You to spider-man For This Useful Post: |
07-30-2008, 17:58 | #8 (permalink) |
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Thanks Bro. In ponyprog, I selected 93Cxx as Dev Type followed by 9346 in the following selection, then I clicked read. Was my setup ok or wrong for the reading? |
07-30-2008, 18:05 | #9 (permalink) |
07-30-2008, 18:30 | #10 (permalink) |
No Life Poster Join Date: Feb 2006 Location: TÜRKİYE / konya
Member: 238439 Status: Offline Thanks Meter: 608 | hi brother look shema : http://www.lancos.com/e2p/si-prog-v2_2.pdf 100% 93cxx good http://www.lancos.com/prog.html |
08-02-2008, 14:39 | #11 (permalink) |
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Ok, Now I managed to build a SI-SIPRO BASE. But, I couldnt find the LM2936Z-5, so I used the 78L05 (A9831) Now i m getting DEVICE NOT FOUND , NOT DETECTED. |
08-02-2008, 14:46 | #12 (permalink) |
08-04-2008, 08:17 | #14 (permalink) |
Member: 238439 Status: Offline Thanks Meter: 608 | yes friend 93c46 |
which cable for which one phone | hooshi | Infinity-Box | 5 | 06-21-2008 13:14 |
how to know which flash is red which one brown | after89 | SonyEricsson (USB-Smart) | 0 | 05-12-2006 05:40 |
Which is the best solution to unlock new sagem ? which one has the better support ? | gsmnice | ARM9 BASED M62 / M62+ | 1 | 10-27-2005 17:01 |
ppm - which one is which | Immortal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-22-2002 02:13 |
Which one can it unlock? | laxxe | Motorola Old Legacy (EMMI) | 0 | 09-08-2001 21:49 |
