CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
08-28-2009, 16:40 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: Liverpool UK
Member: 402904 Status: Offline Thanks Meter: 26 | Ford 6000 sound problem I have a Ford 6000 CD. All i'm getting is a constant hiss no matter what I do with the volume. It is the same, if I play a CD or radio, I just get hiss. Can anyone help please? Thanks in advance, Regards, Jules. |
08-28-2009, 22:53 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Africa
Member: 909783 Status: Offline Thanks Meter: 829 | This following possible can lead to quiteness in Ford. A. If anyone have try to rewire the car before and 2 speaker wire bridged together by kissing each other long sound goes off. B. Moisture from darsh board form AC if get to the pcb while unit on can result similar. C. Tools touch audio line in pcb or screw fell inside while repairing the stereo. D. Speaker coil is bad or melted to bridged together hinder others from working. E. May be wire i.e audio channel is in contact with the car body which is 100% negative. F. Others? |
Code for ford 6000 CD Tuner LHD, please? | Peca | CAR Electronics | 7 | 07-11-2010 18:38 |
urgent code for car radio ford 6000 CD / | mobi-soft | CAR Electronics | 2 | 03-29-2010 20:32 |
FORD 6000 CD '' LOCKED '' problem | murat332 | CAR Electronics | 6 | 11-11-2008 10:09 |
Ford 6000 CD RDS EON code problem | prosndp | CAR Electronics | 0 | 08-24-2006 23:27 |
Need Help for Ford 6000 RDS-Eon | jonkar | Off Topic Zone | 1 | 04-12-2006 14:48 |
