Go Back   GSM-Forum > Non GSM/Mobile Related Forums > CAR Electronics
CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes.
Old 07-25-2019, 12:37   #16 (permalink)
Member: 2918331
Send your PM link or new damp 25C1606
Old 07-25-2019, 23:54   #17 (permalink)
Member: 2197400
Thanks Meter: 64
Originally Posted by Lviv2015 View Post
Good day.
Could you unlock it? since I also failed to get the unlock code on the forum.
39100-T1V-G04-M1. I also read the dump of memory 25C512. on the top board.
BestR
Lviv2015
The data in these memories is the same for all radios
Old 07-26-2019, 07:51   #18 (permalink)
Moderator
shooting@orange's Avatar
Member: 469145
Thanks Meter: 4,359
Cannot see code in this dump either
wbr
__________________
Do NOT pm me for code, use the forum like everyone else
Old 07-28-2019, 19:10   #19 (permalink)
Member: 2918331
Hello
From my research, the car is unlocked only when the VIN code of the car coincides with the VIN code which is written in the radio !!!
(This information is available when radio is turned on from servis menu.)
So having an American Honda model, and the radio is for the United States. I wanted to replace the European model, bought on ebay. And I thought that there would be no problems. Mistaken ..
The European model has a security code, based on ANDROID.
Thank you for the time I've been given. Since there is no further sense, try to read the dump, unless you look for a solution differently.
Old 08-02-2019, 14:26   #20 (permalink)
Member: 2197400
Thanks Meter: 64
This radio is a manufacturer of Fujitsu Ten. The code is not possible by serial number
Only from flash dump
Old 08-03-2019, 12:39   #21 (permalink)
Member: 2918331
So I found the code for my radio, I had two ways.
1. I could go to the officials and give VIN the car from which his radio was removed.
2. By the method of sorting other dump m29w128, I still found the address where the unlock code is.
P.S. It remains only to properly connect it to your car, and change the VIN dump. Not to enter the code every time you turn on the power.
Now I understand why they take the money for it, but thank you for the Raimax tooltip
BestR
Lviv2015
Old 01-14-2020, 14:40   #22 (permalink)
Member: 2942613
I am also currently under going through torture of purchasing a Fujitsu Ten audio navigation unit through eBay UK and trying to make it work in my 2016 Honda HR-V Thai version.
It seemed very simple to unlock the head unit through its serial number but having failed I have realized through this thread that either Honda dealership has to do that or the code is to be extracted through EEPROM memory dump.
Went to local Honda dealer and they couldn't figure out what menu / sub menus in the Honda Diagnostics software to follow to re code the new unit.
Extracting the 8 PIN chip and reading the memory seems tricky to me and I am not sure if its safe or otherwise.
It will be very helpful if someone knows what flow chart to follow in HDS to re-code the unit and also guide me the procedure to read the memory dump so that I could find an appropriate workshop who really know how it is supposed to be done.
The sticker on top of the unit has : 39100-T8M-E55-M1, manufactured: May 2017
Old 01-14-2020, 14:55   #23 (permalink)
Moderator
Member: 469145
Thanks Meter: 4,359
Take it to your local decoder to decode...
wbr
__________________
Old 01-14-2020, 15:10   #24 (permalink)
Member: 2942613
Any idea how to re code the unit through Honda diagnostic software, it will save me opening up the unit and extracting the chip
Old 01-14-2020, 15:19   #25 (permalink)
Moderator
Member: 469145
Thanks Meter: 4,359
Only a Honda dealer tool can do these without reading the chip
wbr
__________________
Old 01-14-2020, 15:26   #26 (permalink)
Member: 2942613
Unfortunately I need to tell my Honda dealer how to do it as they have never done it before. Where can I find the procedure ?
Old 01-14-2020, 15:35   #27 (permalink)
Moderator
Member: 469145
Thanks Meter: 4,359
Honda dealer has this information already, if they do not then they are not a registered honda dealer....
wbr
__________________
Old 01-14-2020, 15:38   #28 (permalink)
Member: 2942613
In that case I need to check with another dealer. Thanks for the help.
Page generated in 0.52642 seconds with 7 queries
