CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
02-14-2014, 14:37 | #1 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2120314 Status: Offline Thanks Meter: 0 | help NCDR vdo 1100 opel NCDR1100 gm1100 on the car display appear SAFE ,the ncdr is form another car my pproblem is which flash i have to read , they are 2. its posible to solve this problem enybody who no what to do to solve the SAFE problem? thanks in advance |
12-17-2014, 13:46 | #2 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Czech Republic,Praha
Member: 443771 Status: Offline Thanks Meter: 16 | Hello. I need help. I Opel NCDR the 1100's. Radio is the car checked out, but has a defect. I bought through eBya others that are not checked out. In that EEPROM or Flash are registered information? Thank you very much. |
02-19-2016, 21:48 | #4 (permalink) |
Junior Member Join Date: Feb 2016 Location: Croatia
Member: 2534257 Status: Offline Thanks Meter: 0 | Hello, i've got siemens ncdr 1100 in opel astra g. Radio with: colour display and navigation. I've have some problem becouse previouse owner of car disconnected radio and putt some MP3 radio inside. I connected radio and on display is message DISPLAY SAFE, and sometimes RADIO SAFE. I dont have any option to putt code inside... Please help. |
02-19-2016, 21:52 | #5 (permalink) | |
Moderator Join Date: Mar 2007 Location: WALES
Member: 469145 Status: Offline Thanks Meter: 5,153 | Quote:
wbr | |
02-21-2016, 11:42 | #8 (permalink) |
Member: 2534257 Status: Offline Thanks Meter: 0 | Yes, i went to opel service and connect it to TECH2. There is only options etc: -add thef activation -deactivate from thef control (when i click this and enter code it said: radio is secured for the second (another) group of vehicles. -i have some options for programing (but its only to put if i have CDchanger or navigation, and tyre size.)- this goes fine without error... -radio doesnt give me option to enter code. becouse According to the former owner of radio has taken off because there is no mp3. He put the other, but this is normal operation (ncdr 1100). When I'm trying to get immediately told me display safe. After that I unplugged and plugged (from power) and then I just said radio safe. |
02-21-2016, 11:58 | #9 (permalink) | |
Here are the Opel errors: If you see "DISPLAY SAFE" permanently shown after 10 seconds, this means that the Display has not been correctly programmed to the vehicle. If you see "DISPLAY SAFE" flashing every 10 seconds, this means that the Display is currently in Delivery Mode, and is now ready to be programmed to the vehicle with a OBDII programmer. If you see "RADIO SAFE" permanently shown after 10 seconds, this means that the Radio has not been correctly programmed to the vehicle. If you see "RADIO SAFE" and a beep every 10 seconds, this means that the Radio is currently in Delivery Mode, and is now ready to be programmed to the vehicle with a OBDII programmer. | |
02-21-2016, 12:03 | #10 (permalink) |
Member: 2534257 Status: Offline Thanks Meter: 0 | Here's the deal: in any case we CODE flashing red light on the radio. In any case, when I connect the two jacks on the radio began to play and after a while the display appears safe. When you connect only one jack (which has a main wire + some additional) behind me then radio works and shows no mistake but still flashes CODE light. When you plug in other radio (JVC MP3), display works but has only the option time, date, temperature. |
02-21-2016, 13:03 | #11 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Easy Street
Member: 1614864 Status: Offline Thanks Meter: 429 | Ncdr The NCDR like the CCRT is a 4 digit coded system. It does not marry to the vehicles display upon successful code entry. Tech 2 is not required to marry & divorce. With the ignition on (SAFE) You will need to initialize the code by pushing & holding the AS button. The radio should beep & ask for code CODE ---- 10 If any incorrect attempts have been made obviously it will count down. If waiting for the next attempt - it should display WAIT If all attempts have been taken it will display LOCKED Not all decoders have the facility to decode these systems & can easily mess them up. I have seen them play in test mode for up to 1 hour & then lock up. Hope this helps Regards Billy |
The Following User Says Thank You to billyhoo For This Useful Post: |
