CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
06-23-2013, 10:54 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Barnsley Age: 37
Member: 306991 Status: Offline Thanks Meter: 62 | How to devorce cd30mp3 It has cd30 I have deactivated theft protection with opcom currently still in car working fine Now I want to buy a cd30mp3 but its coded witch also means not had theft protection deactivated (divorced) Can you tell me what I will need to do with the cd30mp3 I can read EPROM no problem but do I use a clean dump? Or what I haven't purchased yet just want to know the process first Thank you Sent from my iPhone 5 using Tapatalk 2 |
06-23-2013, 14:21 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: BG St Zagora
Member: 1363068 Status: Offline Thanks Meter: 819 | What is your radio??-= CODEDRADIO =- Base navigation If models and EEPROM are the same, just try to swap these EEPROM! |
06-23-2013, 14:49 | #3 (permalink) |
Member: 306991 Status: Offline Thanks Meter: 62 | OPEL CD 30 MP3 GM0D30 EHU 2 without display 344 183 129 13190742 DELPHI GRUNDIG D70F3281YGC V850ES/SG2 24C32 smd is the one i have purchased OPEL CD 30 EHU 2 minus without display IMMO 7 643 104 311 BLAUPUNKT D70F3079 M95640 smd TDA7375 is what is in the car now TDA7561 |
06-23-2013, 15:07 | #4 (permalink) |
Member: 306991 Status: Offline Thanks Meter: 62 | CD 30 MP3 344 183 129 13190742 DELPHI GRUNDIG D70F3281YGC V850ES/SG2 24C32 smd Has anyone got a delivery state dump please ?? OPEL CD 30 EHU 2 minus without display IMMO 7 643 104 311 BLAUPUNKT D70F3079 M95640 smd TDA7375 is what is in the car now TDA7561[/QUOTE] Sent from my iPhone 5 using Tapatalk 2 |
06-25-2013, 19:03 | #5 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Tg Mures (Romania)
Member: 246926 Status: Offline Thanks Meter: 107 | Hi!here is an example: 1 Install a reset display. 2 program with your cd30 to the new display using code 7646 3 deactivate theft on both. 4 fit your original display back and program using 1138. I have op com china clone, and when I do disable the theft, I get an error when I do the anti-theft all done but nothing changes.???hardware or software problem? You cant disable theft unless both are coded together in the first place with the same code. So if they have different numbers you cannot deactivate them. Also you cannot deactivate if one has a code and the other is already reset. Of corse not using this codes 7646,1138 it is for example.Every display and radio has different code. In opcom you need to go to EHU -> deactivate theft protection You need the display to be already unregistered for it to work. The easiest way is to use opcom to deactivate theft protection on your existing radio before putting the coded one in. If you send me radio dump i can put in delivery mode. |
The Following User Says Thank You to attilaa0 For This Useful Post: |
06-26-2013, 12:55 | #7 (permalink) |
Moderator Join Date: Mar 2007 Location: WALES
Member: 469145 Status: Offline Thanks Meter: 5,153 | |
06-26-2013, 12:57 | #8 (permalink) | |
Member: 306991 Status: Offline Thanks Meter: 62 | How to devorce cd30mp3 Quote: Deactivated theft protection Placed new stereo in car It works but shows display safe any help?? When new stereo in and I try activate or deactivate theft protection I get programming failed Sent from my iPhone 5 using Tapatalk 2 | |
06-26-2013, 13:06 | #9 (permalink) | |
Member: 469145 Status: Offline Thanks Meter: 5,153 | Quote:
http://forum.gsmhosting.com/vbb/f179...4/#post9526227 | |
06-26-2013, 13:12 | #10 (permalink) |
Member: 306991 Status: Offline Thanks Meter: 62 | How to devorce cd30mp3 I think you miss read I deactivate theft protection on my car Remove my radio Place new radio in it says display safe But I hear sound what do I do now if I try activate or deactivate theft protection it says programming error No where does it ask for radio code Sent from my iPhone 5 using Tapatalk 2 |
06-26-2013, 13:19 | #11 (permalink) |
Member: 306991 Status: Offline Thanks Meter: 62 | How to devorce cd30mp3 Could my new radio be coded and not divorced?? It still plays music in the background and never says radio safe Sent from my iPhone 5 using Tapatalk 2 |
06-26-2013, 14:22 | #14 (permalink) |
Member: 306991 Status: Offline Thanks Meter: 62 | just tried putting eeprom from my cd30 into new cd30mp3 it lasts 30seconds and display safe but i put my cd30 back and all is ok @shooting@orange did you look at my dump? you seem to be the only one helping |
06-26-2013, 19:01 | #15 (permalink) |
Member: 246926 Status: Offline Thanks Meter: 107 | Sorry !I did not undersatand,if you have a CD30 by grundig you can not put eeprom into cd30 by Blaupunkt.Because first has 24c32 and second is with 95640.Not same eeprom. If you have a CD30 by blaupunkt you can put eeprom to CD30mp3 by Blaupunkt.And you don't need anything to do,must worked.Of corse if your cd30 bin is already married with display. Last edited by attilaa0; 06-26-2013 at 19:10. |
