Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
| | #34 (permalink) |
| Moderator ![]() Join Date: May 2009 Location: caribrod europe serbia
Member: 1037717 Status: Offline Thanks: 840
| Easy mate ![]() Open new topic with your dump - and get code ! before that please update location .:: [ READ RULES ] ::. - before you post - |
| | #35 (permalink) |
| Junior Member Join Date: Mar 2009 Location: Buenos Aires, Argentina
Member: 985756 Status: Offline Thanks: 2
| This is solved. Another user helped me in other thread. About this trouble specifically (how to read) I did it as 24c08 how you said here, and adapted it to my eeprom programmer (JDM) in a very crappy mode yeah, but it worked excellent. Didn't find another way to adapt it better and easier with the things I had here. Picture attached. Thanks ! (Also, later did I realize I didn't need to connect all the wires, but I'm a beginner student, didn't know that :/ ) |
| | #36 (permalink) |
| Junior Member Join Date: Dec 2012 Location: Tema
Member: 1853369 Status: Offline Sonork: 312 Thanks: 0
| I need help Hi, please i have a SIVAVA eprom programmer but i dont have the adapter to read eprom so, can you help me find a way of reading the eprom with my programmer?:confused |
| | #37 (permalink) |
| Junior Member Join Date: Aug 2012 Location: sarajevo, Bosnia and herzegovi
Member: 1795354 Status: Offline Thanks: 0
| VW MFD1 Decoding I hope you have managed to connect +12V, SAFE and Ground. More details on how to connect the VW MFD available here (scroll down): VW MFD Navigation System - Firstly there must be some kind of Programmer, serial preferably that you can use to read eeprom from MFD. If you don't have the programmer stop reading this text as it is the most neccessary TOOL to unlock your VW MFD The programmer doesn't neccessarily need to be FIS. Any programmer that can read PIC 24CXX will do. Second, you must connect SDA and SDL pins (see details here) to the PIC24CXX Socket on the programmer. So basically you must know where is SDA and SDL pin on the programmer for the PIC 24C32 socket. Normaly the socket is the place to put the PIC24C32 eeprom in order to read/write it. So in order to find SDA and SDL pins and conncet them to corresponding SDA and SDL pins on the MFD Motherboard you can refer to 24C32 datasheet. Here is an example of the 24C32 eeprom with SDA and SCL Pins: ![]() Connect SDA pin from the VW MFD Motherboard to SDA pin of the 24C32 Socket and do the same for the SDL. Very important: find the 5V pin on the VW MFD Motherboard and bring externaly +5V in order to power the eeprom so it can be read. Bring the ground from the programmer to ground (chasis) of the VW MFD. Once you connected everything power on the VW MFD. Start ICPROG.EXE program in order to read the EEPROM content. Select 24C32 and read it. You should the progress bar and after it some garbled (hyerogliphs). Among the content of the text (most right column of the ICPROG.EXE Screen) you should see some text like (scroll down) 3B0035186 which shows correct reading of the eeprom. If you can see this than save the result into a file and post it here for "Code reading". If you got your reading as hyerogliphs without 3B0035186 than your reading is incorrect and there is no 5V supply provided on your MFD Motherboard which your 24C32 EEPROM needs to operate so you can read its content. Also it could mean that your eeprom is fried (read DEAD) and needs replacemet. If this is the case you must find .bin file that have correct eeprom configuration with CODE that you can use for your eeprom programming. Good luck Last edited by AkaGura; 12-25-2012 at 16:38. Reason: rules |
| The Following User Says Thank You to aamer75 For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to get your P990 connected and unlocked ! | jawad8305 | SETool2 | 4 | 03-16-2009 16:03 |
| How to tether your iPhone 3G and browse the web using your 3G connection | samadgsm | iPhone ,iPod & iPad (Apple Inc. Products) | 0 | 09-16-2008 16:52 |
| heres how to get your own cert with tut | lee3272 | Nokia Multimedia | 2 | 03-30-2008 18:52 |
| How to get your MCC MNC code? | LichKing | Nokia Hardware & Hardware-Repair Area | 0 | 06-17-2006 19:18 |
