CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
04-09-2013, 23:57 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: EL JEM/Tunisia Age: 56
Member: 71213 Status: Offline Thanks Meter: 120 | Kenwood kdc-w4537ua Please reset Dump for CD KENWOOD Model:KDC -W4537UA Dismplay " PROTECT" No probleme IC Power amplifier.... 1000 Thinks |
04-10-2013, 06:39 | #3 (permalink) |
Freak Poster Join Date: Apr 2008 Location: ALGERIA MASCARA
Member: 758714 Status: Offline Thanks Meter: 128 | Try to keep the <3> and <6> key while pressing the reset and continue to hold after releasing the reset button. You should have a display that says "DC ERR" or "DC OK". If "DC ERR" appears press <1>. Now press <2> and you should get a screen that says "DC #". # Be anything from 0 to 4. 0 otherwise press and hold <2 |
The Following User Says Thank You to nigrou For This Useful Post: |
04-10-2013, 15:52 | #4 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: harrach
Member: 330208 Status: Offline Sonork: https://forum.gsmhosting. Thanks Meter: 69 | Quote:
The TDA7850 integrates a DC offset detector to avoid an anomalous DC offset on the inputs of the amplifier which may be multiplied by the gain, and result in a dangerous large offset on the outputs, which may lead to speaker damage through overheating. The feature is enabled by the MUTE pin and works with the amplifier unmuted and with no signal on the inputs. The DC offset detection is signaled out on the HSD pin. @nigrou if you know how to disable the DC ! | |
