CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
04-25-2014, 14:29 | #1 (permalink) |
Junior Member Join Date: Oct 2008 Location: Lithuania Age: 33
Member: 889682 Status: Offline Thanks Meter: 3 | Navi plus (rns-d) code help Can samone please help me with my AUZ1Z1, tried everything changing 10,20,30 lines, burning in 4 other dumps with known code, rewrited 24c16 many times with no luck to unlock. Keeps telling me that the code is wrong Original Dump: sendspace. com/file/ygp6jl Thank You! |
04-25-2014, 16:41 | #3 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Ukraine
Member: 1617831 Status: Offline Thanks Meter: 3,639 | The dump from Explos : http://www.2shared.com/file/qhp40MxS...navi_dump.html |
04-25-2014, 18:47 | #5 (permalink) |
Member: 1617831 Status: Offline Thanks Meter: 3,639 | Hi. Here is your Original file with the new code.. Rest in PM. http://www.2shared.com/file/1V7D8brE...ode_0xx8.html? |
04-25-2014, 20:56 | #6 (permalink) |
Member: 889682 Status: Offline Thanks Meter: 3 | Solved! Big thanks to masterskay62 and tate45 As i am newbie to all of this i probably did few mistakes. Here's some things for other newbies: First lesson: to connect 24c16 2 resistors and a com port is best programmer (using old pci com board and windows xp - amazingly fast) Second lesson: AUZ1Z1 doesnt turn on when serial port's ground is connected (connect ground after it turns on) Third lesson: if you leave SCL and SDA connected after turning off and on the navi will reset the SAFE, BUT not one code you input will work even if you put in the correct one. As far as i tested you just have to wait till SAFE resets. (could be better methods dunno) Last edited by Explos; 04-25-2014 at 21:06. |
The Following 3 Users Say Thank You to Explos For This Useful Post: |
