CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
10-23-2008, 11:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: PORTUGAL-Viana do Castelo Age: 38
Member: 796252 Status: Offline Thanks Meter: 30 | Opel display switch |
10-23-2008, 11:35 | #2 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Krusevac, Serbia Age: 56
Member: 58263 Status: Offline Thanks Meter: 19 | Try with pressing button 1, 6, or both 1+6 for about 10 sec., I cant remember now the right procedure but one of three upper mentioned for sure! |
The Following User Says Thank You to neper For This Useful Post: |
10-23-2008, 12:27 | #4 (permalink) |
No Life Poster Join Date: May 2001 Location: Lazarevac,SRBIJA Age: 48
Member: 4772 Status: Offline Thanks Meter: 556 | Vauxhall Radios - radio works normally after entering code but display doesn't work This often happens when a radio belonging to a car with a larger display (10 segment) is fitted to one typically with a small centre console display (8 segment). e.g. transferring the radio from a Vectra to a Corsa. The CAR300, CAR400 and CDR500 can support both display types but it needs to be told which display type to use. Here is how is done on a CDR500: With the car ignition on, press and hold buttons 3 and 5 together and switch on the radio whereupon it will show either DISPLAY 8 or DISPLAY 10. Keep the buttons pressed until the radio beeps and the display will change from 8 to 10 or vice versa. Release the buttons, switch the radio off and then back on and hopefully the radio will now operate correctly with your display. Here is a list of buttons to hold in on other models Keys used to toggle display mode Make Buttons CAR300 4 + 6 CAR400 4 + 5 CDR500 3 + 5 regards |
The Following User Says Thank You to steva For This Useful Post: |
10-23-2008, 12:44 | #5 (permalink) | |
Member: 796252 Status: Offline Thanks Meter: 30 | Quote:
Opel display connecion | portugal v3 | CAR Electronics | 19 | 05-28-2011 23:28 |
project around opel display emulator - protocol | et.com | CAR Electronics | 1 | 09-03-2007 20:31 |
opel astra display | ibrahimtamary | CAR Electronics | 0 | 04-16-2007 22:30 |
radio opel display safe | patric | CAR Electronics | 3 | 03-15-2007 19:00 |
3310 display switches on after a periode of minutes, thereafter off again | digiuse | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-10-2004 08:47 |
