CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
11-23-2012, 21:34 | #1 (permalink) |
Junior Member Join Date: Nov 2012 Location: Spain
Member: 1843531 Status: Offline Thanks Meter: 0 | Problem Radio Code Blaupunkt 2040 |
11-23-2012, 22:36 | #4 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Republic of Yorkshire
Member: 538927 Status: Offline Sonork: M1DJF Thanks Meter: 891 | amigo tendrá que cargar el volcado de su radio para obtener el código aquí. como no hay códigos de números de serie aquí. Translation friend you will need to up load the dump from your radio to get code here. as no codes from serial numbers here. |
The Following User Says Thank You to M1DJF For This Useful Post: |
11-24-2012, 00:18 | #6 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: Las Piedras.Uruguay
Member: 883282 Status: Offline Sonork: DI kronoS Thanks Meter: 432 | Quote:
Esta prohibido escribir el serial de la radio por reglamento. Si no eres capaz de hacerlo, contactate con algun "decoder" cercano a ti. Saludos desde Uruguay, pais de fobal y vino a granel. "Ivan No, you must connect the EEPROM or MCU of your radio to a reader, and the outcome of their reading, their code is deciphered. Just so. It is forbidden to write the serial of the radio regulations. If you can not do it, then contact any "decoder" near you. Greetings from Uruguay, a country of fobal and bulk wine." g8gle traduce | |
The Following User Says Thank You to kbzaloka For This Useful Post: |
11-24-2012, 10:16 | #7 (permalink) | |
Member: 1843531 Status: Offline Thanks Meter: 0 | Quote:
Now I understood. but as memory sack radio, do I have to remove the radio and open it? And then with that card where I have to put in that reader? | |
