Go Back   GSM-Forum > Non GSM/Mobile Related Forums > CAR Electronics
CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes.
Old 02-28-2016, 04:35   #481 (permalink)
Member: 2538384
I plan to read / write S22S12I10 EEPROM from Volvo (Alpine) CR-824 (CR-814)
This is an 18pin DIP that is 256 x 4 bit (1k) and is Schmitt input for STORE and RECALL
Can someone confirm programmer and software to use? I can not find S22S12 in any programmers device list.
The Following User Says Thank You to pauljloz For This Useful Post:
Old 09-01-2017, 19:03   #482 (permalink)
Member: 2753459
Hi all,
I want to dump the eeprom of my Smart-Grundig radio. Seems to be a 24c08 (L08).
I'd buy a cheap chinese CH341A-programmer to read the chip, but but I'm afraid to solder out the IC.
Is it possible tread out the memory in-circuit without desoldering?
I found a guy who even write in-circuit with CH341A www,it-feed,de/?p=827
(sorry no link, I am not allowed to post, plz. replace ',' with '.')
using a SOP8 Test Clip.
Can this work on my radio or will I destroy eeprom or even the whole Radio?
TIA,
Werner
Old 09-01-2017, 19:16   #483 (permalink)
Moderator
shooting@orange's Avatar
Member: 469145
Thanks Meter: 4,127
Originally Posted by W.sittich View Post
Hi all,
TIA,
Werner
Simply unsolder the chip, it's safer and better
wbr
Old 09-01-2017, 19:56   #484 (permalink)
Member: 2753459
Thank you for replying shooting!
Simply is nothing, if you don't have proper equipment.
There's nobody who has experiences with reading incircuit?
TIA,
Werner
P.S. This forum software even prohibts quoting for users who have < 10 posts. This is f*#$*ing stupid
Old 09-01-2017, 21:02   #485 (permalink)
Moderator
Member: 469145
Thanks Meter: 4,127
TIA,
Werner
A simple soldering iron will remove the chip.. if you can't do that then take it to your local decoder to decode
wbr
Old 09-02-2017, 14:21   #486 (permalink)
Member: 2753459
Hi shooting,
thanks for replying again, but the point of my question
wasn't whether it is easy or not to sold out a 8 pin SMD-device.
With my abilities and my experience, it is not safer.
There is a pretty probability that the component
will become heat-dead or the motherboard will be damaged.
In my area, there's not a 'local decoder'-service at every corner.
If I have to send the device to a decoder-service, I can buy a new,
better one and even cheaper.
I was interested in someone had experience with the dumping
without desolder. I've got now the possibility of desoldering.
So I'm going to try it anyway to read incircuit.
If someone is interested in the result, I can post again whether success
or s*cks.
CU & nice weekend,
Werner
Old 09-02-2017, 14:41   #487 (permalink)
Moderator
Member: 469145
Thanks Meter: 4,127
Hi shooting,
or s*cks.
CU & nice weekend,
Werner
Soldering in-circuit is the same heat as removing, removing the chip is the simplest possible way to read your chip.
If you read in-circuit there maybe feedback circuitry which may give false reading, and if you have to write back you have the possibility of corruption.
wbr
See: eeprom Removal and Install for Beginers .. [Tutorial]
Old 10-12-2018, 08:27   #488 (permalink)
Member: 2746406
Hello, Do you know any reader for EEPROM 95160. I am not how to read it.
It is in blaupunkt vw radio.
I have pickit3 to usb, JDM programmer to DB9, i2c programmer to parallel port, onboard pliers... Is it possible read it whit any of these.
Please help.
Many thanks in advance!!
Enviado desde mi MI 4LTE mediante Tapatalk
Old 10-12-2018, 08:30   #489 (permalink)
Moderator
Member: 469145
Thanks Meter: 4,127
Please help.
95xxx is the same as 25xxx .. consult your seller as to compatibility
wbr
__________________
Do NOT pm me for code, use the forum like everyone else
The Following User Says Thank You to [email protected] For This Useful Post:
Old 10-12-2018, 08:49   #490 (permalink)
Member: 2746406
And do you know any easy reader for this eeproms? 25xxx and 95xxx. I can buy one. I am very newer
Thanks!!
Old 10-12-2018, 08:56   #491 (permalink)
Moderator
Member: 469145
Thanks Meter: 4,127
Thanks!!
We do not sell programmers here, you need to do this yourself
wbr
__________________
Old 10-12-2018, 09:02   #492 (permalink)
Member: 2746406
Yes, I know, I said if you could recommend me one. It is ok.
Regards
Old 10-12-2018, 09:05   #493 (permalink)
Moderator
Member: 469145
Thanks Meter: 4,127
Regards
We do not recommend programmers, read this thread for types of programmer: How to get your dump ?
wbr
__________________
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.37389 seconds with 9 queries
