CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
06-10-2013, 20:52 | #1 (permalink) |
Crazy Poster Join Date: Oct 2011 Location: Newcastle, UK
Member: 1678683 Status: Offline Thanks Meter: 2 | renr1b102-00 clio locked any chance of someone having a look at the dump file and possibly resetting it? code is 7165 the speedo was changed and had a different VIN number stored, since then the radio comes up locked after a few seconds, have tried changing the vin in the speedo to match the car, and tried changing the radio vin to the speedo vin but still no joy. any ideas? dump files attached of speedo and radio |
06-10-2013, 21:16 | #2 (permalink) | |
Moderator Join Date: Mar 2007 Location: WALES
Member: 469145 Status: Offline Thanks Meter: 5,153 | Quote:
Pass in PM | |
06-11-2013, 09:08 | #3 (permalink) |
Member: 1678683 Status: Offline Thanks Meter: 2 | Hi Ian, just tried that, still no joy, actually tried yesterday doing the same but realised i hadnt put capitals for the vin and was hoping that was going to be it this morning but alas, its still being a pain. also tried the donor speedo vin in the radio and that didnt work either. running out of ideas now :-( |
06-11-2013, 09:19 | #4 (permalink) | |
You need to check ALL systems on the car and adjust the VIN, even the Immo. One option is to change all at once but not hopeful :S | |
06-11-2013, 09:25 | #5 (permalink) |
Member: 1678683 Status: Offline Thanks Meter: 2 | stupid damn car. dont suppose you know off hand if the ecu and immo etc has 24 25 or 94 series eproms? if not im stuffed and he is getting a new radio. do you think by chance, although not hopefull as we have more or less done the same, but if he has the old clocks, fitting them will undo everything these ones have done? |
06-11-2013, 09:29 | #6 (permalink) | |
