CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
02-22-2010, 12:46 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: uk,plymouth Age: 50
Member: 983305 Status: Offline Thanks Meter: 65 | running ford 6000cd on workbench part no.6s61-18c815-cb visteon mcu st92f250cv2qb i want to run these on bench for repair/testing but if i enter code it resets and asks for code again as if it needs to talk to cars can-bus system i cant read/write mcu on these is there a canbus dongle or can i make one for this? or a hidden menu setting for 30 mins of testing ? |
02-22-2010, 13:24 | #2 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Accra , Ghana
Member: 311719 Status: Offline Thanks Meter: 81 | Quote:
The Following User Says Thank You to kmajor1 For This Useful Post: |
02-22-2010, 15:05 | #4 (permalink) |
Freak Poster Join Date: Sep 2009 Location: romania / cluj
Member: 1119324 Status: Offline Sonork: jus do it Thanks Meter: 26 | hy see the doc http://www.***********.com/files/21074362/CONNECT.rar try to connect the pins like in document and will be no problem to activate the code |
The Following User Says Thank You to decoco For This Useful Post: |
01-10-2015, 16:42 | #7 (permalink) | |
Junior Member Join Date: Jan 2015
Member: 2325584 Status: Offline Thanks Meter: 0 | Quote:
I'm having the same problem as the topic starter, only know i'm trying to follow the link wicht doesn't work. Can you help out please? Very much thanks in advance. | |
01-10-2015, 17:43 | #8 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Easy Street
Member: 1614864 Status: Offline Thanks Meter: 429 | Hi, the system requires 2 grounds pin 12 is the common ground (used by many sets) pin 11 is the second ground required by Ford sets Regards Billy |
The Following 3 Users Say Thank You to billyhoo For This Useful Post: |
Hi! HELP! CODE for Radio FORD 6000CD | jorgech | CAR Electronics | 4 | 06-11-2007 10:22 |
ford 6000cd radio code | jenko9873 | CAR Electronics | 3 | 03-02-2007 18:12 |
Code for Ford 6000CD radio | Capt Sensible | CAR Electronics | 3 | 09-16-2006 18:13 |
Ford 6000cd master code | CDX | CAR Electronics | 2 | 03-21-2006 15:09 |
Ford 6000cd | dikomou | CAR Electronics | 2 | 02-24-2006 16:43 |
