Go Back   GSM-Forum > Non GSM/Mobile Related Forums > CAR Electronics
CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes.
Old 01-25-2015, 16:39   #1 (permalink)
Member: 2325802
Touch and connect head unit
Touch and connect head unit,
gm 13 406 438,
Bousch 45 311 6246.
Just got this off a mate to decode never seen one befor but is ment to be a gm unit for the vxr or an upgrade, it came with a screen which iv decoded and the codes dont match up the unit is ment to be 1111 it also came with a standard tid display witch I think is not original to radio
Does anyone no what epprom it has befor I start pulling it to bits.
Thanks jon
Sent from my GT-I9100P using Tapatalk
Old 01-26-2015, 17:53   #2 (permalink)
M1DJF's Avatar
Member: 538927
Sonork: M1DJF
Thanks Meter: 891
You will need to read BGA Omap for code this unit has built in screen I ave done a lot of these
Old 01-26-2015, 18:29   #3 (permalink)
Member: 2325802
I thanks mate im limited to 24, 25, 93 ics at the minute so hope the code works.
Do you if they need a diffrent cage to be fitted as its like singel din unit with dounle din screen.
Thanks.
Old 01-26-2015, 18:32   #4 (permalink)
M1DJF's Avatar
Member: 538927
Sonork: M1DJF
Thanks Meter: 891
The connections are standard at the back but this touch and connect will require gps aerial and mic if you are putting in to s different car cage is a single din cage
Old 01-26-2015, 20:33   #5 (permalink)
Member: 2325802
Have the gps arial already fitted in the car just the mic then, am going to test it out tommorw and see if I can pair it with a bid screen.
Page generated in 0.17589 seconds with 8 queries
