CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
01-25-2015, 16:39 | #1 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2325802 Status: Offline Thanks Meter: 1 | Touch and connect head unit gm 13 406 438, Bousch 45 311 6246. Just got this off a mate to decode never seen one befor but is ment to be a gm unit for the vxr or an upgrade, it came with a screen which iv decoded and the codes dont match up the unit is ment to be 1111 it also came with a standard tid display witch I think is not original to radio Does anyone no what epprom it has befor I start pulling it to bits. Thanks jon Sent from my GT-I9100P using Tapatalk |
01-26-2015, 18:29 | #3 (permalink) |
Member: 2325802 Status: Offline Thanks Meter: 1 | I thanks mate im limited to 24, 25, 93 ics at the minute so hope the code works. Do you if they need a diffrent cage to be fitted as its like singel din unit with dounle din screen. Thanks. Sent from my GT-I9100P using Tapatalk |
01-26-2015, 18:32 | #4 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Republic of Yorkshire
Member: 538927 Status: Offline Sonork: M1DJF Thanks Meter: 891 | The connections are standard at the back but this touch and connect will require gps aerial and mic if you are putting in to s different car cage is a single din cage |
01-26-2015, 20:33 | #5 (permalink) |
Member: 2325802 Status: Offline Thanks Meter: 1 | Have the gps arial already fitted in the car just the mic then, am going to test it out tommorw and see if I can pair it with a bid screen. Sent from my GT-I9100P using Tapatalk |
