CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
05-21-2010, 12:54 | #1 (permalink) |
Moderator Join Date: Mar 2007 Location: WALES
Member: 469145 Status: Offline Thanks Meter: 5,153 | VDO CDR500 not responding So far I've resoldered the chip and checked fuse and power.. The board under the chip has a slight bulge.. Any suggestions.. Last edited by shooting@orange; 05-21-2010 at 13:01. |
05-21-2010, 13:15 | #2 (permalink) |
No Life Poster Join Date: May 2009 Location: MI6
Member: 1037717 Status: Offline Thanks Meter: 985 | What can I say, radio in your hands... From desolder again, check the eeprom, checking voltages, check the pins on the processor, are closer to the eeprom ... maybe desolder ... |
The Following 3 Users Say Thank You to AkaGura For This Useful Post: |
05-21-2010, 13:30 | #4 (permalink) |
Major Poster Join Date: Feb 2008 Location: Romania CV
Member: 715303 Status: Offline Thanks Meter: 41 | i had problem with cdr2005 the double height radio, the panel moved a bit and didnt maked connection with mainboard. |
The Following 3 Users Say Thank You to mmx64 For This Useful Post: |
05-21-2010, 14:40 | #6 (permalink) | |
Member: 469145 Status: Offline Thanks Meter: 5,153 | Quote:
now two points have raised off the pcb.. here: | |
05-21-2010, 15:01 | #7 (permalink) | |
Member: 1037717 Status: Offline Thanks Meter: 985 | Quote:
And because you have to remove it ? It could have been onboard. No problem, drill a small drill, and short-circuit with wire ! It is a double-side, no 5 floors ? | |
The Following User Says Thank You to AkaGura For This Useful Post: |
05-21-2010, 15:28 | #8 (permalink) | |
(These points have continuity between them, even tho they are lifted) Last edited by shooting@orange; 05-21-2010 at 15:34. | |
05-22-2010, 06:14 | #9 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Africa
Member: 909783 Status: Offline Thanks Meter: 829 | I have such case before but i solve it by replacing chip with new one write the original bin into new chip. If this eeprom leg break inside it might look well and ok but can not allow stay current so radio can not power. For circuit if you have super glue use it to make it fixed to pcb because it seems 5 and 6 not ok. |
05-22-2010, 22:02 | #10 (permalink) |
Member: 469145 Status: Offline Thanks Meter: 5,153 | Solved thanks to wilcocoyot Here is the solution... two pieces of CAT5 core soldered from top to bottom... see pics... Can now close... |
The Following User Says Thank You to shooting@orange For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
