Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
10-03-2004, 16:20 | #5 (permalink) |
Insane Poster Join Date: Sep 2004 Location: Philippines Age: 48
Member: 84003 Status: Offline Thanks Meter: 5 | There is password in your mmc, u have to use seleQ to find what the password is. In drive c: inside seleQ, find MMCSTORE. After u find it, send it to your pc and open it with notepad!!! GUd luCk!!! |
10-04-2004, 07:08 | #7 (permalink) |
Junior Member Join Date: Jan 2004
Member: 49137 Status: Offline Thanks Meter: 1 | Did you insert your MMC card in card reader properly. I mean, maybe you inserted on another way around. Check it out. OR You have a cable for 7610, right? After installing your Nokia PC suit, install also the driver for your cable. Using windows explorer, you can access your mmc. And maybe from there you can format your mmc. Good luck. |
10-05-2004, 16:05 | #9 (permalink) |
Member: 84003 Status: Offline Thanks Meter: 5 | Can I ask you, joegel? Do you want to format your mmc or save an existing files inside your mmc? If you want save your existing file, use my above instruction. If not, format it with 9210i. I think your problem was solved ....... Good Luckkkkkkk........ |
10-09-2004, 19:17 | #13 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | Quote:
u r alos right for , locked 7610 mmc. solution must be find out. @kki | |
plzzzz 7610 mmc solution | zakir ahmad | Nokia Hardware & Hardware Repair | 1 | 12-04-2009 08:43 |
7610 mmc help | neiluk | Nokia Hardware & Hardware Repair | 5 | 09-02-2006 15:14 |
Nokia 7610 MMC Crupet | lahoot | Nokia Hardware & Hardware Repair | 4 | 09-01-2006 08:08 |
..7610 MMC Reader Problem..Please help... | LoveLess | Nokia Hardware & Hardware Repair | 1 | 03-02-2006 13:37 |
solution 4 7610 mmc | joegel | WD2 & APE (Symbian Phones) | 0 | 10-03-2004 16:56 |
