Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
08-27-2003, 10:46 | #1 (permalink) |
Junior Member Join Date: Aug 2003 Location: sweden Age: 45
Member: 37567 Status: Offline Thanks Meter: 0 | 8310 only locked for calls! I've got a 8310 that works in all ways except for outgoing calls. I can send SMS and recieve calls etc. What is the problem? It does seem to be locked to a specific operator (Comviq - Sweden) though, but using this operator should enable all functions right? Thanks in advance for you help. /Owen |
08-28-2003, 00:14 | #4 (permalink) |
Insane Poster Join Date: May 2002 Location: Wales UK
Member: 12065 Status: Offline Thanks Meter: 0 | If you can get a DCT4 IMEI editor you could change the IMEI and unbar it. This procedure is illegal in most countries so i dont advise it. You can search the net for one but i have not been able to find a free one or one that doesnt cost the earth. Good luck. Not to go against daloser's verdict on the phone but in the UK if the phone is barred you cannot do anything with the phone. It switches on and lets you enter the menu but you will either not get any reception at all or you will get the "Sim Reg Failed" message. If have never seen one that has been able to recieve calls or send messages as i would think this would defeat the object of barring the phone. Not sure if this is the same for other countries. Also, try unlocking the phone to see if that sorts the problem. If not try another sim card in the now unlocked phone and see if that works (If it does the phone is not barred). If you need the unlock codes to enter you can go to the relevant part of this forum and get it or post your imei and the current network provider code (I believe Comviq GSM is 24007 but you better check) and i will post the unlock codes for you. Hope that helps, Rebels Advocate. Last edited by Rebels Advocate; 08-28-2003 at 00:22. |
Blackberry 8310 powering off when call arrives | beerfoote1 | BlackBerry (RIM) | 1 | 04-13-2009 01:04 |
BlackBerry 8310 no network sos call only | sagtel | TORNADO - SIM | 3 | 06-15-2008 11:32 |
only locked to outgoing calls! | owen | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 09-13-2003 22:24 |
nk 8310 switch off on call | thecult | Nokia Hardware & Hardware Repair | 6 | 07-04-2003 03:16 |
BE1 not receive incomming calls. only make outgoing calls | DrMobile | Alcatel & TCL Old Models | 1 | 05-23-2002 19:19 |
