Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
05-17-2002, 11:58 | #1 (permalink) |
Junior Member Join Date: Oct 2001 Location: Philippines
Member: 6954 Status: Offline Thanks Meter: 3 | can somebody guide me on ringtone change?? can anybody help me or guide me on changing ringtone on any nokia fones? and wat software exactly do i need?... i have here with ringtone manager, ppmsplit fix, ppmmanager, knok95. i've seen some posts here but i cant understand exactly what to do. i'm afraid to try it bcoz i might do the wrong procedure and end up to damage the fone. and where can i get full flash and ppm files? what are the file names/types of full flash and ppm files? i would be glad and appreciate if somebody could help me on this... thanks... more power on this forum.. [email protected] icq#2241013 |
05-17-2002, 22:11 | #4 (permalink) |
Major Poster Join Date: May 2002 Location: Bangkok, Thailand Age: 50
Member: 11955 Status: Offline Thanks Meter: 0 | Hi..all I would like to know about ToneID which is used in Converter Program to convert to *.re format. How do I know that I can use start ToneID address & end ToneID address? I use 010, 011, 012, 013, 020, 030, 040,... ToneID. They could not work some address when I flashed into my phone. Please let me khow. Thanx |
05-18-2002, 13:20 | #5 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Philippines
Member: 2034 Status: Offline Thanks Meter: 24 | Hi mate! For as long as you have your backup nothing is impossible... We have a working crack available on the net using this FlashTone 2.02 or 2.05 by Ice Dragon... cheers to him! You just need first ofcourse the FLASHTONE, second LOGGER by B-PHREAKS, lastly the FAID Calculator. These the third party software that you may be able to use in modifying, adding tones in your nokia cellphone. Most import as always you have to have your own Nokia FLASHER box and an MBus/M2Bus datacable... REGards |
05-18-2002, 18:21 | #6 (permalink) |
Member: 6954 Status: Offline Thanks Meter: 3 | using ppm manager for tone changing hi all! i used knok95 build 22 to read full flash from my 3210v510 and using ppm manager 0.91 to add 2 ringtone from 3310 and i flashed it again to my 3210v510 and it worked but my problem is i got no network. someone told me that i should use bphreaks logger and tek log calculator. where can i find those sw and how to use it? thanks.. [email protected] icq# 2241013 |
05-19-2002, 08:37 | #8 (permalink) |
Member: 6954 Status: Offline Thanks Meter: 3 | hi! THanks so much i got tek log calculator and bphreaks on this site: http://www.gsm-software.host.sk/Software/Nokia1.htm i'll post the result if i did it lan123 [email protected] |
05-20-2002, 10:33 | #9 (permalink) |
Member: 6954 Status: Offline Thanks Meter: 3 | ringtone added successful hi all! i've successfully added 2 ringtone to my 3210 and it's working fine now. is it possible to change message alert and wat sw do i need to change it? i've heard of conversion of *.rttl to *.re, wer can i find such software? lan123 [email protected] |
05-27-2002, 10:08 | #10 (permalink) |
Member: 6954 Status: Offline Thanks Meter: 3 | 6150 ringtone problem hi all! i've added some ringtones to my 6150 v5.22, it was successfully added to the fone the only problem i got now is when somebody calls it doesnt ring, just like in silent mode. what could be the problem? can somebody help me with this? thanks in advance... LAN |
06-15-2002, 07:34 | #11 (permalink) |
Junior Member Join Date: May 2002
Member: 11978 Status: Offline Thanks Meter: 1 | Buy Flashtone v2.09... here is the website: www.ed2k.com.ph its one of the most efficient way to change/add a ringtone or change an alerttone hope this helps... not only should you use flashtone but you need FLASHTONE V2.09 the real thing not the crack one... good luck |
06-15-2002, 16:11 | #12 (permalink) |
Member: 6954 Status: Offline Thanks Meter: 3 | flashtone didnt work hi! i used flashtone to add/change ringtone, the tone was added but the problem is the tone didnt play correctly, it's out of tune what is the problem? lan123 |
06-15-2002, 16:45 | #13 (permalink) |
Member: 11978 Status: Offline Thanks Meter: 1 | you better make sure that the Flashtone is the REAL and the LATEST! go to: http://www.ed2k.com.ph for more information |
06-16-2002, 02:18 | #14 (permalink) | |
Freak Poster Join Date: Feb 2002 Location: WORLD
Member: 9468 Status: Offline Thanks Meter: 0 | Quote:
Hi some one can guide me how to change my imei number (Nokia N85) | AlonSe | Nokia Base Band 5 ( BB-5 ) | 9 | 03-08-2010 11:44 |
need help can somebody guide me how to sx4 n82 | beans | Nokia Base Band 5 ( BB-5 ) | 12 | 10-28-2009 06:56 |
pls, can somebody help me on my N-gage | musa2 | Nokia Hardware & Hardware Repair | 1 | 03-31-2007 15:27 |
can somebody tell me which mobile ufo crack can unlock and which on it kills | ashvin | Panasonic | 3 | 07-06-2005 21:37 |
can somebody help me on t720i subsidy password? | edoy | Phone Unlocking Codes & Maps | 0 | 11-01-2003 17:21 |
