Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
09-23-2008, 17:01 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Location: Bangladesh Age: 39
Member: 92043 Status: Offline Thanks Meter: 0 | Drakkarious Hack phones and All apps installer{unsigned and Expired Files}work e66 Have you ever wanted to install an unsigned file without having to sign it like we used to on s60v2 phones? Have you ever wanted to send an application over bluetooth and install it right away on the receivers phone? Well this is your lucky day, Drakkarious.sis, an application especially developed for this very same reason. All you have to do is install this application, follow the on screen instructions wich you easly learn after doing it 1 time and your ready to hack any phone, anywere... With this app you can install: Unsigned, Signed, Binpda, Non-Binpda, Dated, Out-Dated files etc etc etc... Give it a try and you'll see. Inside instructions: Change phone date to 15-05-2007 Drakkarious Hack Compilation. This program will install: CapsOn CapsOff HelloCarbide X-plore *Note: If you have any of these programs installed on your mobile there is no problem continuing the installation, however, this ones have been tested, none others, so if you have any trouble during the procedure uninstall the ones you have and re-install Drakkarious.sis. After installing please follow this procedure: 1.-Run X-plore and press "0", tick the 4 boxes (dont un-tick if ticked already) 2.-Without closing X-plore switch to the menu and run hellocarbide 3.-Inside hellocarbide press options and chose Menu1 and answer "yes". 4.-Go back to X-plore and extract installserver.exe and CProfDriver_SISX.ldd from your c:\hack.rar into c:\sys\bin 5.-Restart your phone. 6.-Install whatever you want on your phone, even if it is unsigned Run capsOff if you wish to see private folders using X-plore and capsOn to hide them again Note: I advice you to always hide private folders after you have completed whatever you wanted to do inside them... Enjoy... Signed(lol) Drakkarious Special thanks to: Olti BinPda Leftup FCA00000 NOTE: AFTER COMPLETING YOU MUST RESTART YOUR PHONE TO BE ABLE TO INSTALL ANY APP, AND REMEMBER TO ALWAYS PUT YOUR PHONES DATE BACK TO THE PRESENT AGAIN, ALWAYS CHOOSE THE CORRECT VERSION FOR YOUR PHONE, AND IF YOU DONT YOULL NEED TO MANUALLY REMOVE INSTALLSERVER.EXE FROM C:\SYS\BIN\ USING X-PLORE AND HELLOCARBIDE... IF YOU MAKE THIS MISTAKE PLEASE REPEAT THE PROCESS USING THE CORRECT VERSION: FP1 OR PREFP1 Devices list: Pre-FP1 devices: ------------------- Nokia N77 Nokia E61i Nokia E65 Nokia N93i Nokia N91 8GB Nokia E62 Nokia E50 Nokia 5500 Nokia N93 Nokia N73 Nokia N80 Nokia N71 Nokia N92 Nokia E70 Nokia E60 Nokia E61 Nokia 3250 FP1 devices: --------------- Nokia 6124 classic Nokia N82 Nokia N95-3 NAM Nokia E51 Nokia N95 8GB Nokia N81 Nokia N81 8GB Nokia 6121 classic Nokia 6120 classic Nokia 5700 XpressMusic Nokia 6110 Navigator Nokia E90 Communicator Nokia N76 Nokia 6290 Nokia N95 Nokia E66 Nokia E71 FP2 devices ------------- Nokia 5320 XpressMusic Nokia N78 Nokia N96 Nokia 6210 Navigator Nokia 6220 classic Specific devices ------------- Nokia 3250 v4.14 Nokia 3250 v4.60 Nokia 5500 Nokia E50 Nokia E51 Nokia E61 VersioN 2,01(3) <- released on 13 \ 06 \ 2008 VersioN 2,02(3) (BETA) <- released on 15 \ 06 \ 2008 Just for those who cant see private folders with the normal version of hellocarbide... Thanks To Drakkarious 07/08/08 Friends if you want to install new version of Xplore u have to first install the latest version of Xplore and then install Drakkarious so that will replace to the new one.And now im adding the Xplore 1.22 version which has full access to System folders with this Xplore we can access the folders without caps off thanks to Disabled for this file Moved from OS9.1 Apps - Dansco ""http://rapidshare.com/files/147738205/nokia_e66_e71_installer_unsigned_and_Expired_Files __01.rar"" "http://rapidshare.com/files/147738206/nokia_e66_e71_installer_unsigned_and_Expired_Files __02.rar" |
Drakkarious Hack - All applications installer {unsigned and Expired Files} lattest | serseg.gsm | Nokia Multimedia | 25 | 05-05-2009 00:07 |
Drakkarious hacking | ForTrans8 | Nokia Base Band 5 ( BB-5 ) | 0 | 08-23-2008 10:26 |
