Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 03-10-2003, 17:40   #1 (permalink)
Member: 20989
HELP! Dongle not found on my computer
I just bought a DCT4 Calc, but my computer won't detect my LPT-port dongle. I've read a little bit about low power being a possible reason. Someone help me out, please! I've tried running programs to increase PC workload, but it didn't help.
Old 03-10-2003, 20:16   #2 (permalink)
Member: 6265
same prob here but it doesnt work even with external power from usb
Old 03-10-2003, 23:20   #3 (permalink)
Member: 20989
I tried it on my friend's computer and it works, he has XP, but I don't think that's the reason because I tried another XP computer that didn't find the dongle like my windows 98 computer.
So now he's my best friend.
Old 03-10-2003, 23:20   #4 (permalink)
Member: 22257
are you try reset port - its specially program for this..maybe works properly......?????
Old 03-10-2003, 23:22   #5 (permalink)
Member: 22257
when you want to try this programm mail me-j send you....
Old 03-10-2003, 23:29   #6 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 60
solder a wire with 5v usb power to pin 20 on the amtel inside the plastic case.
Then it should work
If you are not sure what you are doing - I am not responsible
Old 03-11-2003, 00:55   #7 (permalink)
Member: 6265
not working on xp for me. also not on win98..
gggggggggrrrrrrrrrr
Old 03-11-2003, 14:24   #8 (permalink)
Member: 1385
DESKEY drivers
Did you install DESKEY drivers???
If not try to find on net archive
dk2wn32.exe and install it, after that try your calculator.
Samir
[email protected]
Old 03-12-2003, 19:11   #9 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 60
Guys, this is how I fixed the problem:
1) get yourself a USB cable
2) Cut off the square end of USB cable and strip back to the wires
3) Find the RED wire and cut down others (not needed)
4) Remove outer shell/casing from dongle
5) Take RED wire from USB cable and solder it to pin 20
6) Replace casing - take care in doing this
7) I then used a hot glue gun to seal area where USB cable coming out.
8) Plug dongle into LPT port
9) Plug USB into USB port on pc
10) EnJoY the use of DCT4 calculator!!
To help you find pin 20, I have a pdf document with pin out.
Please view it here:
http://www.yeldar.co.uk/atmel4dct4.zip
Yeldar
Please note; I take no responsibilty or accept no liability for any damages to your dongles or pc while attempting this modification. It worked 100% for me. If in any doubt, seek further advice.
Old 03-12-2003, 22:20   #10 (permalink)
Member: 6265
did that still not working lol ****ing dongle
Old 03-12-2003, 22:44   #11 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 60
Perhaps dongle faulty???
I have spent hours searching and checking out possible problems and apart from setting bios, this is most common modification to make it work!
Yeldar
Old 03-12-2003, 22:52   #12 (permalink)
Member: 6265
Nope. Dongle's working fine in other pc's
Old 03-12-2003, 23:08   #13 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 60
have you checked bios settings??
This can cause same fault
Old 03-12-2003, 23:11   #14 (permalink)
Member: 19390
x Gnosis:
Can you read the ATMEL inside your dongle???
This way you can help lot of people to make their own dongles...
Thanks in advance.
Old 03-12-2003, 23:52   #15 (permalink)
Member: 6265
yeah man.. tested with all possible bios settings...
the stupid thing is that all other dongles work 100% in this pc..
jawad need help dongle not found sameed_j Easy-Unlocker 1 08-15-2009 14:25
help,spider not setup on my p30 simorgh SpiderMan 1 04-03-2009 15:19
help dongle not found gsm_era Easy-Unlocker 4 02-27-2009 12:52
pls help in my box dongle not found gsmsalik Easy-Unlocker 7 08-21-2008 00:24
Lurker Gold NOT WORK ON MY COMPUTER!!! Uvedovle BF, BG, TH, BHx Series 13 01-08-2004 17:30
Page generated in 0.25462 seconds with 10 queries
