Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
03-10-2003, 17:40 | #1 (permalink) |
Freak Poster Join Date: Feb 2003 Age: 45
Member: 20989 Status: Offline Thanks Meter: 0 | HELP! Dongle not found on my computer |
03-10-2003, 23:20 | #3 (permalink) |
Member: 20989 Status: Offline Thanks Meter: 0 | I tried it on my friend's computer and it works, he has XP, but I don't think that's the reason because I tried another XP computer that didn't find the dongle like my windows 98 computer. So now he's my best friend. |
03-10-2003, 23:29 | #6 (permalink) |
No Life Poster Join Date: Jun 2002 Location: UK/Espaņa Age: 54
Member: 12578 Status: Offline Thanks Meter: 60 | solder a wire with 5v usb power to pin 20 on the amtel inside the plastic case. Then it should work If you are not sure what you are doing - I am not responsible |
03-11-2003, 14:24 | #8 (permalink) |
Freak Poster Join Date: May 2000 Location: Germany
Member: 1385 Status: Offline Thanks Meter: 1 | DESKEY drivers Did you install DESKEY drivers??? If not try to find on net archive dk2wn32.exe and install it, after that try your calculator. Samir [email protected] |
03-12-2003, 19:11 | #9 (permalink) |
Member: 12578 Status: Offline Thanks Meter: 60 | Guys, this is how I fixed the problem: 1) get yourself a USB cable 2) Cut off the square end of USB cable and strip back to the wires 3) Find the RED wire and cut down others (not needed) 4) Remove outer shell/casing from dongle 5) Take RED wire from USB cable and solder it to pin 20 6) Replace casing - take care in doing this 7) I then used a hot glue gun to seal area where USB cable coming out. 8) Plug dongle into LPT port 9) Plug USB into USB port on pc 10) EnJoY the use of DCT4 calculator!! To help you find pin 20, I have a pdf document with pin out. Please view it here: http://www.yeldar.co.uk/atmel4dct4.zip Yeldar Please note; I take no responsibilty or accept no liability for any damages to your dongles or pc while attempting this modification. It worked 100% for me. If in any doubt, seek further advice. Last edited by yeldar; 03-12-2003 at 19:18. |
03-12-2003, 22:44 | #11 (permalink) |
Member: 12578 Status: Offline Thanks Meter: 60 | Perhaps dongle faulty??? I have spent hours searching and checking out possible problems and apart from setting bios, this is most common modification to make it work! Yeldar |
jawad need help dongle not found | sameed_j | Easy-Unlocker | 1 | 08-15-2009 14:25 |
help,spider not setup on my p30 | simorgh | SpiderMan | 1 | 04-03-2009 15:19 |
help dongle not found | gsm_era | Easy-Unlocker | 4 | 02-27-2009 12:52 |
pls help in my box dongle not found | gsmsalik | Easy-Unlocker | 7 | 08-21-2008 00:24 |
Lurker Gold NOT WORK ON MY COMPUTER!!! | Uvedovle | BF, BG, TH, BHx Series | 13 | 01-08-2004 17:30 |
