Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 03-14-2003, 16:43   #31 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 59
He has just sent another email asking for you to maybe check that the sound card is not conflicting the IRQ.
This may also be conflicting with LPT port
I have asked for soft to check and reset LPT port, so we will have to wait & see..............
Old 03-14-2003, 16:49   #32 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 59
I have just done a quick search, and found a pdf doc for parallel pro, but it has settings for LPT port which may be of some use or help...........
http://www.siig.com/manuals/8parapro-d.pdf
Old 03-14-2003, 21:13   #33 (permalink)
Member: 6265
I already used a proggy to reset LPT port but still not workin
Will now about the IRQ set to 7. Anyway im not having conflits with my sound card or other devides and LPT
Old 03-18-2003, 03:08   #34 (permalink)
speed's Avatar
Member: 936
Thanks Meter: 2
TO ALL
I HAVE THIS SOLUTION LONG TIME ALREADY! VERY SIMPLE, NO NEED TO OPEN THE DONGLE! NO NEED TO PUT WIRE OR USB!
1) JUST RUN THE SOFTWARE "Siemens Direct IMEI Writer 4.00 by Maxfron" ONCE OR TWICE. THEN CLOSE IT.
2) THEN RUN DCT4 CALC
ENJOY!
Does anyone here have Counter-Strike 1.6? or where I can download it?
Old 03-18-2003, 07:59   #35 (permalink)
Member: 20989
I can't find a download anywhere!
Old 03-18-2003, 09:45   #36 (permalink)
speed's Avatar
Member: 936
Thanks Meter: 2
HERE YOU GO http://groups.yahoo.com/group/speed_...ter%204.00.zip
Old 03-18-2003, 19:47   #37 (permalink)
Member: 6265
Stills not working on my pc.
Old 03-18-2003, 23:04   #38 (permalink)
Member: 20989
Originally posted by yeldar
Guys, this is how I fixed the problem:
1) get yourself a USB cable
2) Cut off the square end of USB cable and strip back to the wires
3) Find the RED wire and cut down others (not needed)
4) Remove outer shell/casing from dongle
5) Take RED wire from USB cable and solder it to pin 20
6) Replace casing - take care in doing this
7) I then used a hot glue gun to seal area where USB cable coming out.
8) Plug dongle into LPT port
9) Plug USB into USB port on pc
10) EnJoY the use of DCT4 calculator!!
To help you find pin 20, I have a pdf document with pin out.
Please view it here:
http://www.yeldar.co.uk/atmel4dct4.zip
Yeldar
It works! Yeldar rules.
Old 03-22-2003, 21:51   #39 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 59
I have received an email from a member of my own forum who has had the same problems as some of you.
For those who are still struggling, this is what he said:
Hi Yeldar,
I thought I had better email you and pass on some information regarding the dongle you sold me a few weeks back.
The dongle worked fine on my desktop PC but the software wouldn't open on my laptop, even with a USB lead plugged in and feeding 5v to Pin 20 on the Atmel chip. It just came up Dongle Not Found.
However I purchased a mains powered 4 port USB hub and have just tried it with that with surprising results. It works absolutely fine with the hub connected between the laptop and the dongle, provided I don't use the mains adaptor supplied. If I apply the mains adaptor I get the Dongle Not Find message again but it works A1 with just the hub connected which will do me though I don't understand why that should be.
The hub comes brand new with mains adaptor and A - B USB cable and cost me £10.50 + £2.50 P&P which is a very good price for one of these items from Ebay's site, but I have since found out that Zignig are selling them direct off their own website for £9.75 + £3.50 P&P. The web address for purchase is:
http://www.zignig.com/
I hope this helps you and any member of the forum who has a similar problem to me.
So I hope this helps you - worth a try??
B.R.
Yeldar
Old 03-22-2003, 22:07   #40 (permalink)
Member: 6265
Sure it worthes a try!!
Sounds good to me.. just still dont get why the hell the dongle dont works normaly.. very weird thing
And.. Yeldar, tks for still standing on this matter.
Old 01-08-2010, 07:37   #41 (permalink)
Member: 7844
Thanks Meter: 181
i had same problem with infiinty .. dongle not found ...
i just solved this second .. i tapped it 3 times on top of the box and now it works :P
Old 02-12-2010, 23:22   #42 (permalink)
Member: 1234846
A problem with the USB driver exists on some Windows Operating Systems/releases when the IntraVUE USB dongle is moved from the USB port it was originally installed on to any other USB port.
You should be able to do this. In versions 2.0.4 and 2.0.5 the USB driver may have problems.
This has been fixed in the driver supplied by our vendor. You may update your driver using their software available at this link.
http://i-vue.com/intravue/dongle/Install.exe
To begin the process, REMOVE THE USB DONGLE.
Next, launch the just downloaded executable and check Uninstall. Then select the 'Begin Uninstall' button, as shown below.
When that is complete, you can the un-check the Uninstall checkbox and check the USB checkbox at the top, as shown below.
You will get a message asking you to be sure the USB dongle is NOT connected.
When the above is completed you will get a success message. The New Hardware Wizard may or may not run depending on whether Windows thinks this is a new install or a re-install. Intravue will now find the dongle regardless of which port it is inserted into.
Source FROM
http://networkvisionsoftware.com/for...php?topic=55.0
jawad need help dongle not found sameed_j Easy-Unlocker 1 08-15-2009 14:25
help,spider not setup on my p30 simorgh SpiderMan 1 04-03-2009 15:19
help dongle not found gsm_era Easy-Unlocker 4 02-27-2009 11:52
pls help in my box dongle not found gsmsalik Easy-Unlocker 7 08-21-2008 00:24
Lurker Gold NOT WORK ON MY COMPUTER!!! Uvedovle BF, BG, TH, BHx Series 13 01-08-2004 16:30
Page generated in 0.37299 seconds with 8 queries
