Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 11-07-2004, 13:47   #1 (permalink)
Member: 90033
Question help on installing games/apps
i was wondering if u could help me wif a problem.. i was looking through this site and saw the game sango which i realy wanted to download... as i saved it to my desktop i unziped the file so the game is now under sango.app
the problem is installing the game to my nokia...
also.. i was browsing through the forum and a person said sango needed a password to play..
is ther any way of playing the game wifout being asked for a password
any help would be greatly appreciated
Old 11-07-2004, 15:32   #2 (permalink)
Member: 78878
explication
when u download a game/application for your smart phone and u find a file *.app with the same name of the game/application this file is the enregistred/cracked version..
so u just have to use a file explorer (after installing the game/application and sending the *.app file to ur phone) to copy the *.app file to the folder where the game/application have been installed..u will be asked if u want to overwrite ('cause a *.app file with the same name already exist) say yes and u have a full/enregistred version..
Old 11-07-2004, 21:03   #3 (permalink)
Member: 90033
im still confused
i dont exactly know wot u mean.. can u explain step by step
the problem is i dnt know how to installe sango.app to the phone
Old 11-08-2004, 21:26   #4 (permalink)
Member: 78878
step by step
can a moderator please erease this message
thanx
Old 11-08-2004, 21:28   #5 (permalink)
Member: 78878
step by step
wich phone is yours?
to install a game or application or a theme on your phone u need a file with the extension *.sis
once u have this file on your PC u need a way to connect your PC with your phone for this u have 3 way :
1 - bluethooth (BT) : u need a compatible PC with a BT card/port integrated on it or u can buy it
2 - InfraRed (IR) : u need a compatible PC with a IR card/port integrated on it or u can buy it
3 - serial connection : u need a specified cable wich is compatible with your phone
finally u need a software wich will allow your PC to recognize your phone (for nokia smartphone u can use Nokia PCSuite aviable for free on www.telecharger.com or in the official website of nokia)
once u have all that u have two way to install a software on your phone :
a - u can transfer the file to the phone and after what install it (it's easy to use with Nokia PC Suite)
b - u can install it to the phone directly by double-click on it (follow the instruction of the Nokia installer)
if somthing look complicated give me a reply
Old 11-10-2004, 19:27   #6 (permalink)
porfia_7's Avatar
Member: 85082
Wink
You've forgotten another way to install some games.
4.- you can transfer the file with a mmc cards reader/writer. Once in the mmc, just switch on the phone and run the sys file.
->You can also install some cracked games copying the cracked game to the system/app folder.
->And you can install .blz games with blzinstaller. first of all install the blzinstaller (a sys file) by the way you choose. and then just copy the .blz game to the mmc and run the blzinstaller.
and enjoy...
Old 11-10-2004, 20:32   #7 (permalink)
Member: 78878
thanx very much
tthanx for the details..
but u forgot that dewo_333 is begginer, and I don't want to confuse him with so many information in the first time..remember step by step
and for the card reader i've never use it and I don't know a lot of thing about it..
Old 11-11-2004, 02:08   #8 (permalink)
Member: 66920
Lightbulb Tips, Tricks & Tools for Installations
This post seemed to have disappeared, now it's back ...?
Administrator, please delete it and accept my severe apologies for the inconvenience.
Last edited by Maître Désastre; 11-11-2004 at 16:45. Reason: Glitches in the System
Old 11-11-2004, 16:42   #9 (permalink)
Member: 66920
Lightbulb Aspirin against headaches
The software you need can be downloaded from http://www.Forum.Nokia.com/main/0,6566,034-63,00.html. While you are there, you might wish to get the Audio Suite from http://www.Forum.Nokia.com/main/0,6566,034-62,00.html as well. Don't forget to serial number, which is free but necessary for the installation. The Theme Studio is located at http://www.Forum.Nokia.com/main/0,6566,034-301,00.html. Of course a lot of third party synchronizing software is suitable as well, i.e. programs like Nokia's PC Suite from other manufacturers.
There are three methods to transfer files to and from the phone when you are done editing them: attached to an MMS or e-mail to your phone, vía data cable, Infrared (IrDA) or Bluetooth (BT) with the Nokia PC Suite (http://www.Nokia.com/nokia/0,8764,42289,00.html) or any other synchronizing software, or simply by inserting the MMC card in a card reader connected to the PC, copying the files and then putting the card back into the phone. Make sure the filenames do not contain any spaces or special characters.
You will want to install a file manager on your phone (from Epoc, Psiloc, SeleQ), in order to be able to move files into the correct directories, e.g. into the picture gallery, sounds, apps, whatsoever.
Once the application is installed, start the file manager on the phone and go to C:\system\apps or E:\system\apps if the program is on the memory card. From there, enter the \[program's name] directory and delete the original .app file.
Transfer the patched .app file to the phone as described above and move (cut & paste) it into the program's directory with the file manager on the mobile phone, thereby replacing the original .app with the patched one.
When the software has not been cracked but you have a key generator or serial number, always install the matching version number first and register it. Subsequently you can upgrade it with a more recent maintenance (same number before the dot) release. For the next full version (from 2.xx to 3.xx, for instance), a new serial number is necessary.
Good luck.
Old 11-14-2004, 05:30   #10 (permalink)
Member: 66920
Installing Java software
To use Java games on a Nokia mobile phone follow these simple steps.
Download and install the Nokia PC Suite. Choose the correct version for your phone model. Download a Java application. The Nokia 6600 supports both MIDP 1.1 and MIDP 2.0.
Connect your Nokia phone to a computer vía Bluetooth, Infrared or a data cable. Launch the Nokia Application Installer and use it to install the software. Click the Install Application Icon (open folder) on the left side under the title of the application installer. Go to the folder where the files have been downloaded and decompressed, and select a program folder. Double-click it. You will see the .jad file that accompanies every .jar file. It is basically just a text file that contains the name and the filesize of the .jar file (if present locally) or the URL for Over-the-Air (OTA) download from a server. Double-click it to download it to your Nokia phone or to open it for installation. Wait until the installation process has finished, then delete the installation files from the phone (back them up on a PC).
To uninstall software use the Application Manager >>remove or, as a more drastical approach, format the user area.
To back up Java applications from the phone, use a File Manager (e.g. from http://www.epocware.com) to find the location of the program within \System\Apps\ on either the phone or the MMC. Its folder could go by the name of the game, \Mario for instance, or have a name like "101dce6a" or "101db17d" or something else. Just try to find the folder you need and copy it to the computer. Well, it won't be a .jar or .jad file, but your game will be backed up.
By the same token, if a software comes as a folder only, install as follows:
  • Connect your MMC memory card to your computer either through BT/cable/IrDA or vía a USB card reader.
  • Copy the folder containing the program to the phne, where it should be placed in \SYSTEM\APPS\, so put it on your MMC in \SYSTEM\APPS\
    The end result should be: \SYSTEM\APPS\GameTitle
GoBoy Emulator files: If the phone complains about a "message in unknown format" when sending a GoBoy application, for the Nokia 6600 for instance, from the computer to the phone, the installation should work as follows: Send ‘Filename.gb’ or ‘Filename.gbc’ to the phone vía IrDA, etc., after which you will get another message. Just use a file explorer like SeleQ to find the filename that you have sent and Cut & Paste it into the GoBoy folder in your MMC or into the phone's memory. Copy ROM file to e:\GoBoy, run GoBoy Plus, select ‘Game’ then ‘Play’.
Last but not least, always try to keep as much phone memory free as possible. This means to copy contact list, saved messages, pictures and sounds to the memory card. Software should always be installed on the MMC as well.
Hope this helps. Good luck.
Old 11-16-2004, 16:48   #11 (permalink)
dan21's Avatar
Member: 37060
hi i need full verson software for s60 anybody help me pleaseeee help me
Old 11-22-2004, 16:30   #12 (permalink)
porfia_7's Avatar
Member: 85082
Man, this forum is full of stuff!
Just use the search engine (look the top of the page) and you'll find whatever you want...
if you don't know what to search, just visit any page of Simbian software.
Old 11-24-2004, 00:09   #13 (permalink)
Member: 90033
Red face reply post
the post above states that you jus transfer the folder to /system/apps in the mmc card.. but wen i open nokia pc suite and open mmc card... there is no folder saying systems apps..
p.s to transfer files to my fone i use a bluetooth
Old 11-24-2004, 05:40   #14 (permalink)
Member: 78878
u need a file explorer (seleq, FExplorer...) that u install on your phone, it will allow u to transfer any files from the inbox to another directory..u must have this app it allow u to browse your phone 100% not like the default one provided by Nokia..
here I attach Seleq for 7650 it work perfectly on my 6600 and it's easy to use (like any other) try it and u will never regret it..
File Type: rar SeleQ_v1.65i_7650_cracked_lvckyluke.rar (84.2 KB, 69 views)
Old 11-24-2004, 15:59   #15 (permalink)
porfia_7's Avatar
Member: 85082
the folder don't appears cause it's a hiden system folder.
I use a card reader to move files to my mmc, it's faster than bluetooth or irda.
help, on installing games on Cect K2 plz yildirim400 Chinese Models & Cloned Phones 0 11-05-2009 04:46
Needs a help on UIQ 3 apps installation indz01 Sony Ericsson 3 09-24-2008 10:44
How to install Games/App for ZTC N38 dj123456reza HTC & PDA WM( With Touchscreen) 0 12-20-2007 07:30
How to install Games/App for ZTC N38 bonny HTC & PDA WM( With Touchscreen) 0 12-14-2007 07:34
any one can help with installing games in my D807 i cant do it fireman009 Board, Server and Login Problems/Support 1 11-30-2006 05:14
Page generated in 0.98111 seconds with 12 queries
