Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 10-30-2007, 06:12   #1 (permalink)
Member: 607914
Thanks Meter: 36
Rock Your Mobile Call Recorder Pro v1.10 -BiNPDA
This useful application will let you record incoming and outgoing phone calls. CallRecorder can start recording automatically or ask whether to record a conversation or not - this will depend on the rules you set.
How to start:
1. First, you should turn CallRecorder on. To do this, press Options and select Settings command. In Settings dialog you can turn CallRecorder on and set up some options;
2. After that you should set rules for CallRecorder - considering these rules the application will or will not record phone calls;
Main view:
You can find all recorded phone conversations in the main view of CallRecorder. The following functions are available here:
* Play record. You can change the volume with joystick left/right arrows while a record is being played. To change speaker from loud to quiet or vice versa set an option Play volume in Settings dialog to a corresponding value;
* Call a contact or a phone number. If the highlighted record has a phone number, you can dial it even without exiting CallRecorder - just press Call button or select this command;
* Send via Infrared/Bluetooth/Email/MMS you can send the recorded conversation with the help of this command;
* View contact (hot key: '*') displays a dialog with a contact;
* Properties (hot key: '5') displays a dialog with record's detailed properties;
* Delete (hot key: 'C') deletes marked records;
* Delete all (hot key: 'Pen+C');
* Pack deletes all records that don't have a sound file;
* Refresh actualizes the list of records.
http://rapidshare.com/files/65384491/CallRecorderPro_1.10.rar
shoda..................
The Following 3 Users Say Thank You to klaklair For This Useful Post:
Old 10-31-2007, 18:28   #2 (permalink)
Member: 455215
phone recorder wm5
anyone have a phone recorder (record conversations) for WM5 HTC TyTn?? please and thanks!
Rock Your Mobile Video Converter for Nokia Smartphones v1.2a WinALL Cracked-SyMPDA DIGITAL BABU Nokia Multimedia 7 10-28-2008 15:45
Warning - Rock Your Mobile - call recorder. Hi Folks Easy-Unlocker 0 09-25-2008 15:39
Call Recorder Pro 1.10 without beep ege051 Nokia Multimedia 0 09-06-2007 08:03
!!!!!Rock Your Mobile Ringtone Converter v1.0 work with all mobiles muhammad irshad Nokia Multimedia 1 06-26-2007 18:19
Page generated in 0.18606 seconds with 10 queries
