How to cleare Nokia Life timer ? Hello Who knows how to cleare Nokia Life timer ? Thanks,before |
Read eeprom from the phone which have 0 timer... than write eepom to other phone which need to 0 timer...... than update faid, sp and IMEI.. done.. Best Regards, Wahab |
i want eeprom 00000 timer to 3310 579 |
2moro.. from my OFFICE.. I will upload 0timer eeprom for 3310 to my WEB SITE.. than post here LINK.. Best Regards, Wahab |
good work man |
1 Attachment(s) 3310 Eeprom backup with 0 life timmer. Best Regards, Wahab |
And for that stupid clearing timer, u are able to overwrite calibration data? I think is not good for phone. krtko |
krtko you are 110% right. I can confirm that after cloning eep data you'r phone is not working properly. We tested using calibrated GSM Tester and the phone is fail with succes on all RF test after cloning, i'm sure that energy managment tests also will fail... in most cases TX level is higher than normal and will afect you'r health. L. |
Mr Guciano, some months ago you said you have the adresses where lifetimer is stored, maybe you can share them with us, or in private. I think it's stored on 3 bytes like this: When phone comes new LT is 65535255 and in hex FFFFFF. Am I right ? I too I'm against rewriting eeprom area. If I'm forced to do so, I use Wintesla (with PKD-1) to reset phone to default values, but can't do calibration. Yes indeed, in the most cases, when you rewrite eeprom, tx level is higher, and not good for health. I can reduce power with Wintesla, but this is not a good solution. Best is to have original eeprom. |
I tried to write an sw to do this automaticly but the main problem is the life timer is not stored in an fixed location and the bigest problem is that in the same version memory is allocated dinamic and life timer is changing location after power on/off... until now I did not find an algorithm 100% sure for this and was not an big demand for this sw... so if is required I can change only life timer location after 2-5 tries... maybe another solution is to backup eep calibration data ( after I will find the location ) and save this in an "empty" eep... this can be done if is required I think... yes without tester it's impossible to calibrate TX phone on all levels and specially TX- IQ ( this is realy nasty to calibrate ) ... damage is already done... |
